cannot get my clutch out
Old Dec 28, 2008 | 11:01 AM
yellowevo82's Avatar
Having problems getting my engine seperated from my tranny. i went on evomoto followed the instructions by putting a flat head screw driver between the wedge collar and throw out bearing. My buddy pushed the fork towards the driver side and i pryed the opposite way with all my strength and could not get a release. Please do not refer me back to evo moto. If anybody has any tricks they used please let me know. I need to ship my motor/trans out and i need to do this asap. Thanks
Old Dec 28, 2008 | 11:12 AM
JEP's Avatar
JEP
Its been a while since I had my tranny out but I believe you dont need to pry just put the flat head screwdriver right behind the wavy spring and turn your screwdriver either way clockwise or counter clockwise at the same time pull the tranny away from motor.
Old Dec 28, 2008 | 11:25 AM
JEP's Avatar
JEP
I know you dont want to here this but I thought I would check out the evomoto website and see if their writeup was good. I would have say it is dead on correct, take your time and study the pics they have posted. I think your rushing you must put the screwdriver in the correct spot and just turn in like your were tighting a screw. Placement of the screwdriver is the key...
Old Dec 28, 2008 | 11:29 AM
I did not see where they said you have to twist and then seperate the trans from the motor. I will have to go back n double check
Old Dec 28, 2008 | 11:35 AM
The only thing i see i could of been doing wrong is i was prying to the right of the fork, im going back outside to pry to the left of the fork.
Old Dec 28, 2008 | 12:01 PM
JEP's Avatar
JEP
remember to first insert the screwdriver then pull the fork. When you have compressed the wavy looking spring then turn the screwdriver and start pulling the tranny away from the motor. Turning the screwdriver is what pops everything loose. Let me know how it goes...
Old Dec 28, 2008 | 12:04 PM
JEP's Avatar
JEP
Like I said your not prying all you have to do is turn the screwdriver like you were turning a screw. One tip might be is to use a large flatheaded screwdriver the larger the head the better....
Old Dec 28, 2008 | 02:25 PM
got it, thank you, just needed some finagaling...
Old Jan 21, 2009 | 10:54 AM
20gmr's Avatar
its like one of those really easy things once you have done it before... haha kicked my butt thats for sure
Old Jan 21, 2009 | 11:33 AM
goofygrin's Avatar
Even for KevinD who has changed LOTS of Evo clutches, it still took some jiggling/a few minutes to get my X's TO bearing to release.
Old Feb 15, 2009 | 06:58 PM
xspsi4's Avatar
Next time just unbolt the pressure plate 1 bolt at a time and release the trans that way.
Old Feb 15, 2009 | 07:03 PM
WHTEVO's Avatar
The way i have done it is to have one person go through the access cover on the top of the tranny with a long screwdriver and the other one does the same thing from the bottom. Try that and be patient. Good luck.
Old Feb 28, 2009 | 05:06 AM
humgaling12's Avatar
i am also stuck at the TOB removal step. how do you know when the bearing is out?
Old Mar 1, 2009 | 10:09 PM
CJEVO9MR's Avatar
im at this same point today i started at 1pm got my head and intake off t case seperated and now just got to finish takin my tranny out
Old Mar 3, 2009 | 07:02 PM
Evonrails's Avatar
its best to practice on the new clip to see how it works. Doesn't take alot of force at all
