boost problem
Old Dec 31, 2008 | 05:18 PM
Evofletch's Avatar
boost problem
im only hitting 10psi on my stock evo i wanna know what it could be someone please get back to me the only thing im thinking is a boost leak let me know please thanks doug.
Old Dec 31, 2008 | 05:25 PM
EvoFredo's Avatar
yeah thats not right it should spike to 18 and decrease towards redline on a stock ride. it might be a boost leak or a vaccum leak. make sure your lines are correct. might consider a manual boost controller in the near future. 20psi all day
Old Dec 31, 2008 | 05:27 PM
Tnnrx7's Avatar
Try this:
https://www.evolutionm.net/forums/ev...er-5-02-a.html
And make sure your vac lines are zip tied down REALLY good and there are no holes / cuts in them.
Old Dec 31, 2008 | 05:28 PM
Evofletch's Avatar
yeah it sucks but i have a hallmans boost controller and i slowly turned it up and i got nothing i turned it to full boost and still 10 all day
Old Dec 31, 2008 | 05:29 PM
Kdash106's Avatar
do you have the hard spring in?
Old Dec 31, 2008 | 05:31 PM
Evofletch's Avatar
my buddies got one of those line testers i guess that what im gonna have to do
Old Dec 31, 2008 | 05:34 PM
Tnnrx7's Avatar
More than likely it is a leak somewhere.
Check it out and let us know what you find out.
Old Dec 31, 2008 | 05:46 PM
Tvo's Avatar
Tvo
Hmmm
Tvo's Avatar
Tvo
From my experience, usually big boost leak issues involve the couplers and most couplers would blow right off under boost and that would be an obvious problem cuz your car would act horrible, but maybe ur hose clamps is holding the coupler on for dear life lol. Check em all and I would check the throttle body first, then work around the couplers til you reach the turbo. Keep me posted.
Old Dec 31, 2008 | 05:49 PM
Evofletch's Avatar
ill deff keep you posted i mean i spike 12 and that is it
Old Dec 31, 2008 | 06:05 PM
gsr0801's Avatar
COMMON answer, check for boost leak.
Old Dec 31, 2008 | 10:59 PM
cthcky5's Avatar
u have a boost leak...check ur vaccum lines
Old Dec 31, 2008 | 11:16 PM
oneonlywgs's Avatar
+1
Old Jan 1, 2009 | 12:30 PM
Slo_crx1's Avatar
Sounds like something's screwed with the lines going to you mbc...12psi is stock wastegate pressure. A boost leak tends to be a bit more noticeable as it causes some other weird issues too like stumbling idle, much richer afr's than normal, and like said above usually the coupler blows right off unless there's a slit in it.
Vacuum lines at the manifold leaking would cause a higher than normal idle due to the air leak.
Old Jan 1, 2009 | 12:32 PM
aeroweenie's Avatar
If you just installed the boost controller, you probably have it hooked up wrong. Otherwise, as already mentioned, boost leak.
