CEL thrown
Old Jan 2, 2009 | 10:14 PM
Malwarebytes's Avatar
CEL thrown
OK, let me start with the basics. I just bought a 2006 Evolution MR from a private seller. The car had 6,900 miles on it. I got an oil change at 7,800 miles and now it has 8,800. The car has a boost controller and a new turbo back exhaust with a cat delete. It also has a new Walbro fuel pump. The car has been supposedly 'tuned'.
Now, I went to P&L Motorsports (they specialize in WRX Sti's but they have a Dyno and I wanted to know the car specs before I start adding onto it). So the car puts down 290 HP to the wheels and about the same torque. Everything went smoothly during the dyno.
Three days later (today) I get in my car and I see the dreaded 'Service Engine Soon' lit up. I take it to autozone and it throws code P0300 which supposedly means a cylinder misfire was detected, random cylinders.
I read that P0300 is common when someone tunes the ECU, anyone have any more details? I was planning on stopping by AMS and letting them deal with it -- but information first is better .
Thanks!
Old Jan 2, 2009 | 10:23 PM
MR_Evo_Rob's Avatar
Check the plugs. and yes, P0300 is Random Cylinder Misfire Detected
Old Jan 3, 2009 | 12:06 AM
Thanks, I will check them tomorrow. The car is running just like it did before the code was thrown. Any other suggestions I will check in tomorrow. Thanks!
Old Jan 3, 2009 | 07:22 AM
Muad's Avatar
Erase the code and keep driving. If your car is not breaking up at high rpms under WOT, then your plugs are most likely fine. P0300 is very common. I carry and scan tool in my car, that way if the SES comes on, I can check it real quick. I 99% of the time just erase the codes as I usually see the P0420 due to running a TP.
Good luck!
Old Jan 3, 2009 | 05:48 PM
OK, funny follow up. I remember they (P&L Motorsports) took the spark plug cover off and hooked up some cables to the spark plug wires (I think). Well anyway, I remember they had trouble putting the cover back on and were moving some other cables.
Today, I popped the hood, jiggled some of the wires and the code disappeared. Something is flaky. I'll likely deal with it when I replace the spark plugs and wires at AMS.
Thanks for your suggestions.
Old Jan 3, 2009 | 05:56 PM
wevo1985's Avatar
they where just getting your rpm reading off the number one cylinder sparkplug wire. maybe it just had a bad connection or came loose and no one noticed.
Old Jan 3, 2009 | 05:59 PM
Well they specialized in Subies .. probably couldn't handle the Evo . I would have gone to AMS (right down the block) but they wanted me to wait a week or so and well, a baseline dyno is a baseline dyno.
Old Jan 3, 2009 | 06:48 PM
cfdfireman1's Avatar
A "baseline dyno is a baseline dyno" as long as you use the same dyno. I can attest to the fact that P&L's dyno reads different that AMS'. I wouldn't worry too much about the P0300 it is just that a "random misfire".
Old Jan 3, 2009 | 06:53 PM
Slo_crx1's Avatar
Like they said, don't worry about it. That code's been a sore spot for a while. Just erase it and keep going. If it comes back again, there are a few "tricks" I've learned to tune it out, or there is a patch code for EcuFlash that disables the entire p0300 system check.
Old Jan 3, 2009 | 07:15 PM
mt057's Avatar
I have disabled my p0300 using ecuflash and mrfred's prephiery bits. I have not had the code in about 1000 miles. I do not get any studdering on the highway anymore. Search for disable test p0300
evotuner04
For Sale - Cars For Sale
36
Oct 20, 2016 11:36 AM
evotuner04
40
Apr 18, 2015 12:36 PM
evotuner04
Oct 31, 2014 05:18 PM
mmmmbst
Sep 3, 2011 10:17 AM
j255c
Aug 9, 2011 10:13 AM
