Just got P0171 code
Old Jan 3, 2009 | 11:14 AM
powerjjang's Avatar
Just got P0171 code
i just got an p0171 code poped on me last night
is there any common cause that to pop on 03 evo8?
maf? dont seem like its got vacuum leak
only mods i have is a turboback exhaust.
Old Jan 3, 2009 | 11:20 AM
Muad's Avatar
I get this from time to time. Honestly, I ignore it and erase the code with my scan tool.
HOwever, I've read that this could mean that the primary O2 sensor (the one in your O2 housing) might be going bad. So you might want to look into that.
Anyone else???
Old Jan 3, 2009 | 04:59 PM
magyar86's Avatar
p0171 in "system too Lean" (bank 1). i see that on cars that dont have properly scaled injectors. check your LTFT and i bet they are very high. the highest it will show is only +12.5ish if it is thats why your throwing the p0171 code....
Old Jan 3, 2009 | 07:55 PM
powerjjang's Avatar
i erased the code and its didnt come back on yet.. i wonder if thats caused by the rough running on idle cause these past few days my car was running lil rough at idle like misfiring only at idle tho.
Old Jan 3, 2009 | 11:21 PM
magyar86's Avatar
if your starting to see stumbling problems then that is likly due to your LTFT (long term fuel trim) low being maxxed out (+12.5) and it takes a little while for your o2 sensor to get heated up when first started so that stumble is the time it takes for the 02 sensor to get warmed up and your STFT (short term fuel trim) to start adding the extra fuel the car needs to stay at the target afr of 14.7. you will prolly also notice that your WB will be vvery lean or even maxxed out to the lean side during warm up. i just had to fix this exact same problem on my buddy lee's (SN: will05) car today
Old May 27, 2009 | 07:42 PM
mt057's Avatar
I am seeing similar issues. How did you resolve it?
Old Oct 20, 2012 | 01:05 AM
manolo2011's Avatar
interested in knowing about this...
mrm95
Nov 7, 2014 01:04 PM
axiomstyles
Sep 13, 2014 10:55 PM
bigd2011
Lancer Troubleshooting
Oct 12, 2013 09:49 AM
roydollabill
Jul 23, 2013 10:05 AM
09_Lancer_GTS
Jan 12, 2011 02:02 PM
