Aftermarket throttle body with IAC?
Old Jan 6, 2009 | 01:40 PM
SpunEvoIX's Avatar
anyone know of any aftermarket throttle body that has the factory idle air control valve preferably 70mm +...i was looking into the mustang ones but ehhh rather do a straight plug in...i just saw the skunk 2 it looks good and Ive seen the ebay and don't trust it...just looking around to see what i can get!
Old Jan 6, 2009 | 05:14 PM
cssaddictm4's Avatar
I do! I am using a Ford 70mm throttle body with my stock IAC.
I am looking for a picture of it... will post back later.
Old Jan 6, 2009 | 05:36 PM
PATRICK B.'s Avatar
http://www.fftec.com/product.php?pro...2&cat=0&page=1
http://www.fftec.com/product.php?pro...8&cat=0&page=2
Let me know if you have any questions about them
Old Jan 6, 2009 | 09:30 PM
Joshs EVO's Avatar
So I am upgrading the intake also and was told that I can't use a aftermarket throttle body cause it screws up the idle.
So where can I find this mustang manifold and is it a direct bolt on?
What manifolds will it fit on?
Any small details I need to know once I see this throttle body that will prevent it from bolting right up and working right away?
Old Jan 7, 2009 | 08:54 AM
PATRICK B.'s Avatar
You can run the FFTEC i'm or any other aftermarket i/m that is flanged for the 75mm 5.0 Mustang TB
Here's a pic of the TB on the FFTEC I/M
Old Jan 7, 2009 | 09:00 PM
tc17's Avatar
i have 2 accufab 70mm throttle bodies off my viper if your interested.
Old Jan 8, 2009 | 09:29 AM
PATRICK B.'s Avatar
fwiw - Just be careful with the Accufab as i've had some stick on me when i had my 03 Cobras
Also the FFTEC TB is made to hold at least 40ish psi as that's what we tested on my Evo w/o any leaks at the shaft ends
Old Jan 8, 2009 | 10:12 AM
Joshs EVO's Avatar
So can it hold more than 40? This is something that is very important to me since i will be pushing around that PSI
Old Jan 8, 2009 | 12:28 PM
PATRICK B.'s Avatar
The last time i pressure tested my set-up posted above i believe i went to 42psi.
On the dyno i believe the boost spiked up to about 40psi but tapered off to 37 sorry i don't remember the exact # i'm sure i could get a log of the boost but don't have much time to do so
Old Jan 8, 2009 | 07:59 PM
C6C6CH3vo's Avatar
You can also just run without the idle servo by blocking the bypass port and capping. Just set the BISS when warm. Cold start and AC idles rough but other than that idle is better
Old Jan 10, 2009 | 04:21 AM
wspy's Avatar
The new skunk2 68mm is direct bolt on with all sensors!
Old Jan 10, 2009 | 05:04 AM
staatz's Avatar
Originally Posted by PATRICK B.
Will that adapter work with the Bbk 75mm small bolt pattern tb? I have that on my car and I want to fix it hopefully without having to buy a new tb.
Old Feb 24, 2009 | 11:53 PM
konstantinosIX's Avatar
Offtopic...
FPRED with 1350 USD ONLY????
Is it true???
http://www.fftec.com/product.php?pro...6&cat=0&page=1
WTF????
Black_EVO_MR
Dec 7, 2016 09:28 PM
boostawd16
May 25, 2015 08:50 PM
needsboost
Apr 14, 2015 03:11 PM
only0nce
16
Apr 6, 2015 10:37 PM
lancerkuik
Lancer Engine Tech
Nov 6, 2014 06:12 PM
