Anybody currently runing the GREDDY t67 25g kit???
Old Jan 11, 2009 | 07:50 PM
EatSleepBoost's Avatar
I am going to be picking up the Greddy t67 kit used off my friend. I have read reviews on it after searching on here but there isn't any recent threads. Any current evo owners running this????
if so please provide me with your own reviews. i know the manifolds tend to crack. what else should i know, upsides and downsides...??
thanks in advance
Old Jan 12, 2009 | 07:08 PM
bump
Old Jan 12, 2009 | 07:52 PM
h22gordo's Avatar
From the stories I heard.....besides cracking manifolds, this T67 turbo is extremely laggy.
The other downside is that Greddy uses these funky flanges on their kits (I guess their own design) which cannot be used with other manufacturers turbos. You would need a completely new flange welded on if you want to run a different frame turbo.
Old Jan 12, 2009 | 10:12 PM
prockish_03evo's Avatar
I have used the turbo and am trying to sell it! Its a pretty good turbo and spooled alot like a 30r but with 650HP on race gas possible. I made 443 HP and 410 LBFT at a 5500 ft elevation. And thats on a 2.0
Old Jan 12, 2009 | 10:23 PM
tobz's Avatar
Not to bad of a turbo, for old school. E85 around 550. Spool is not to bad.
Really small hotside. Power falls off up top.
Old Jan 13, 2009 | 06:01 AM
Danner's Avatar
Spool is not horrible on this turbo. Damn hot side is extremely small. I bet you could see 20lbs by 4500.
Old Jan 13, 2009 | 07:29 AM
JakeTheVIII's Avatar
Basically an older 35R-ish turbo right?
Probably isnt so bad, will make good power. The spool will probably be the worst part.
Old Jan 13, 2009 | 06:02 PM
thanks for the responses guys. i know they have two different options for hotside sizes and this one has the smaller one. 8cm i believe. Supposedly spool up is better but it does die out at high rpm and boost.
im hoping for some e85 around here but im in NH and we have yet to get any stations....
prockish u ever run more than 23 psi??
Old Jan 17, 2009 | 09:29 AM
bump...
also the intake needs to be 4" where it meets the turbo, any recomendations for a stock replacement piece that would work well? i currently just have the rmr open filter with adapter
Old Jan 17, 2009 | 09:37 AM
Kuba23's Avatar
I used this turbo then upgraded to a 35R I liked the T67 better awesome power quick spool the only thing is yes the manifold is horrible it did crack i had to get a custom one made... If you buying that kit make sure u brace that turbo somehow other wize the manifold will Crack...
Old Jan 17, 2009 | 01:07 PM
94AWDcoupe's Avatar
I had pleasant experience with this turbo as well. Spools 500rpm faster than 35r. Does not lay down up top on 8cm exhaust housing. The 10cm housing is what makes this turbo dull boy. It is capable of around 560whp dynojet.
Old Jan 18, 2009 | 12:03 PM
thanks. good to hear other ppl ran this set-up with sucess. i know somebody who does custom manifolds so i think i will be all set with that.
Old Jan 19, 2009 | 09:14 AM
No i never did. i was planning on but my motor spun a rod bearing. but it spooled 23 lbs at about 4500 rpms on 3rd gear pull
Old Jan 19, 2009 | 10:15 AM
getcha's Avatar
I have been on a tuning pull in a t67'd car. I was actually pretty surprised. I expected it to come on full alot later than it did. Grated this car was meth injected and a *i think* a 2.2 build but I was impressed with it. It was pretty smooth too, but I think the smoothness came a ton from the quality tune
That being said, it was too big for my tastes
Old Mar 23, 2009 | 07:16 PM
my t67 has been in for a few weeks but finally this weekend i will be installing my 1000cc injectors and dip into the 20+psi range... also the dragway here opens up the begining of april so its perfect
