Pistons & Rods for 2.0 Setup?
Old Jan 13, 2009 | 03:41 PM
Chris@nolimitmotors's Avatar
Originally Posted by k2boarder3187
Wiseco Pistons, Manley Turbo Tuff rods
This is what i would recommend, or you could even go with Manley H-beam rods. Let me know if you need any, we have them in stock.
Old Jan 13, 2009 | 03:46 PM
Pure Playaer's Avatar
Drop in pistons / rods right?
I went with Buschur Racing JE Pistons + Crower Rods!
Old Jan 13, 2009 | 03:48 PM
sdfontanini's Avatar
Looking at the Cosworth setup right now.
MSRP: $999.00
The piston is one of the most important components within the engine. It can be subjected to directional change up to 285 times every second and must withstand acceleration forces of 8500g. Cosworth high performance forged pistons are designed and engineered to withstand this type of punishment and still perform. All Cosworth pistons are manufactured using the same methods as our Formula One pistons and include features such anti scuff skirt coating, ulta-strong pins, polished top and patented anti-detonation bands. Additionally, each application uses a unique forging to minimize weight and ensure the strongest possible piston design
MSRP: $999.00
The connecting rod is the vital link between the piston and power. When engine output is increased, the demands placed on the connecting rod increase as well. To ensure engine reliability in all conditions, original connecting rods should be replaced with heavy duty specification parts. Cosworth Forged Connecting Rods are manufactured from high strength 4340 (EN24) steel and machined to exacting tolerances.
Gonna keep looking more into this, thanks for the suggestions guys, and yes just a drop in piston rod setup for now.
Old Jan 13, 2009 | 03:55 PM
Buschur Pistons
MSRP: $680
This custom piston has been built by JE to Buschur Racing specifications. Stock 9:1 compression ratio. Complete set of pistons, pins, retainers, and rings. WE ALSO HAVE THESE PISTONS SIZED FOR YOUR STANDARD BORE - Because these engines are so new, we are offering this solution to customers who would like to do an in chassis forged piston upgrade. This can be done without removing the engine. Use in conjunction with our forged rods for a durable combination that will support over 800hp. NOTE: These pistons are J&E tough skirt coated. This is a special process that helps with the oiling and prevents excess wear.
Old Jan 13, 2009 | 03:59 PM
wiseco piston
Old Jan 13, 2009 | 04:25 PM
WHTEVO's Avatar
I went with Manley Pro "I" beam rods and Wiseco pistons.
Old Jan 13, 2009 | 06:38 PM
SilverBulletIX's Avatar
I'm looking to do the same thing as well. Are all these pistons drop in
Old Jan 13, 2009 | 07:29 PM
Tonba's Avatar
I wonder how the Wiseco 9.3:1 CR pistons would go?
Improved off boost drivability? More torque?
Old Jan 13, 2009 | 08:09 PM
Evo8RA's Avatar
Seeing your thread motivated me to post a new set of Arias 10:1 pistons and Eagle ESP H-beam rods, if you're interested.
https://www.evolutionm.net/forums/sa...ml#post6567586
Mark
Old Jan 14, 2009 | 08:10 AM
good info guys, I'm now leaning towards the Buschur Pistons since I won't be hitting ridiculous numbers, and this will remain mostly a DD and not a full all out race car.
Old Jan 14, 2009 | 11:33 AM
9sec9's Avatar
I would NOT go JE at this time. I've had as many as 4 or 5 sets and am not happy with their attention to service. It's time they understand where at least part of their business comes from.
Old Jan 14, 2009 | 11:45 AM
jmelocik's Avatar
Good info. Thanks, I was thinking about replacing my 9.0:1 Wiseco pistons and Eagle rods with the JE but I think I will hold on to what I have for now. Maybe step up to the 9.3:1 setup.
Josh
Old Jan 14, 2009 | 11:58 AM
Personally I haven't heard good things about Eagle, I know you should definately stay away from their cranks, I've seen a few blown motors with the Eagle cranks.
Old Jan 14, 2009 | 12:26 PM
jmelocik's Avatar
I have no experience with the Eagle cranks however I know several high powered Evo's running the rods with no problems. I have been told that the Wiseco/Eagle combo is good to 600hp.
Josh
