57 P trim hotside for evo?
Old Jan 14, 2009 | 07:45 PM
Murf's Avatar
Ok due to a tragic engine seizure on my RX-7 project I'm considering taking the T04E 57 trim turbo for that project and using it on the evo. The turbo is a turbonetics T04E 57 trim bual BB, I was using a 1.0 hotside on the RX to shift the power up in the rpm band a little. Now what I was wanting to know from some of the bigger turbo guys is what turbine section should I go with if I want to use this on my evo? Keep in mind that I will be maxing @ about 7500rpm. Also sould I drop it to a T3 flange or keep it T4 flange? What are your oppinions on using a .68 turbine section to help keep the spool livable? Thanks.
