need help just installed injen icp kit now care sputters
i just got done installing the injen icp kit with intake and now everything is fine except when im driving if i put it in nuetral the rpms drop to about 5or 6 hundred same thing when im sitting idle its fine then if i tap the gas to either 2,4,6hundred itll drop down does anyone know what is causing it i didnt have the problem before the icp kit
Agreed however it go's by drive cycles so depending on how much you drive it may take a couple days. Also anytime you redo piping a boost leak test is a must
Like evane said, reconnect the battery and let it idle for about 10-20 mins without touching the throttle.
i have done ALOT of work on the injen kit to get it to run properly and on a straight ended intercooler. you have a open pipe somewhere . clamp not tight enought or a hose thats not fully put on right. basically boost leak test if you can. The hoses that came with the kit are complete junk except for the 90 degree one. check my website for more information
Installed the Injen kit myself not too long ago. Replaced all my clamps with T-Bolt Clamps, the ones that came with it were crap. The couplers aren't all that bad really, seemed to do the job for me. Did a boost leak test on my car and there's no leaks except in my throttle body, which is one of the more common leaks. Getting that fixed here soon anyhow.
but i do have the same issue as you, seems like my rpms drop to 500 or so when ever I take it up to 5K rpms or more and just let off. If anyone else is experiencing this same thing and have found a fix let me know. I've already played around with timing and changing my AF ratios still no resolution.
Thanks
- Steve
Thanks
- Steve
You'll probably hear the same thing over and over again, the car needs a tune for the extra air coming in. It'll keep doing this until then, an ecu flash will fix this without a problem.
thanks guys
