power loss after 5K rpm?
Old Sep 14, 2003 | 09:08 PM
ytsejam's Avatar
i've read some threads that mentioned that evo won't pull as hard after 5K rpm?
is this true? if yes what can cause this? boost limit? i know that the peak is around 3500 rpm.
i've also seen some dyno results and after that 3500 rpm the curve start going down...
any good explanation?
sorry i am not a turbo expert, in fact this is my first turbocharged car. what can i do to fix this? ECU re-flash?
Old Sep 15, 2003 | 07:08 AM
BeenWaitin4Evo's Avatar
The boost drops off after about 3000-5000 RPM. It's just how the computer controls things.
Get a computer upgrade (whether it's flash or piggyback, plenty of threads on that subject) and it should fix most of that feeling.
Old Sep 15, 2003 | 09:38 AM
sccavee's Avatar
Re: power loss after 5K rpm?
The Boost fall is a small portion of the loss above 5K. The biggest issue is the air/fuel mixture the stock ECU runs. The car runs supper rich above 5K which is dropping power. With a S-AFC you can gain back over 30 WHP with re-setting the mixture.
