kelford 272 vs FP4r
Old Mar 25, 2009 | 11:41 AM
  #46
SRT-TO-EVO's Avatar
Originally Posted by MattsT67
definately FP... Kelfords are snapping like woah
They're using the same cores as FP now .
Old Mar 25, 2009 | 12:54 PM
  #47
DDATuned's Avatar
Originally Posted by DSMer...
Damn, again I get screwed. I waited for about 1 month for the cams to get here. And looked everywhere and no damn camn cards. I too will be using the evo springs/retainers for my head. I was told that someone had them 'tested' and they have better stiffness than the BC springs/retainers. I think they will be just fine.
Did both of you install the cams yet? How are they sounding? Helping spool bigger turbos any better?
I installed mines the week I got them. I am running stock springs and retainers reving to 7500 with no problems so far except the phantom knock sums I am getting from not bleading the lifters correctly. They sound pretty mean at idle.
Old Mar 25, 2009 | 04:04 PM
  #48
DSMer...'s Avatar
Originally Posted by SRT-TO-EVO
Well if you have a problem with your cam they can tell you build date/when they were first purchased through an id number on it.
I don't know for few more months if I will/have a problem with the cams. Having problem with my head arriving.
I just wanted to know if the info on the card is necessary for installation or to degree the cams.
GOod to hear Remy since I will be running the stock Evo springs/retainers as well. BUT, do you think that perhaps the phantom knock is perhaps because of the aggressive cams?
Old Mar 25, 2009 | 06:18 PM
  #49
Early EVO's Avatar
On my 04 RS. E85, 30 psi, IX turbo. Making 395hp, 398tq. BR race core, intake, exhaust, 255 pump, PTE1000's. FP4R's, ARP's. Stock motor otherwise. Cams do idle pretty aggressively. But the car makes a little better top end power than about any other combo of cams on a IX turbo that I have seen on my Mustang dyno. Seen about every brand name set of cams on an 8 and now IX that are out there. Also broke two sets of Kelford IX cams now. Never seen an 8 cam break of any brand. Think alot of people make all their decisions on what others post up on the net. Yet you don't always know of that info is accurate and what kind of real testing they have done. Kelfords of FP cams are going to work fine. As for a large difference in power of the two. Can't really see it on a car thats making 450hp or less. Also both sets work fine on stock springs up to 7800rpms or a little more. Many cam companies scare customers into buying spring sets. Unless you have a built block and head, and are going to spin it over 8000 all the time. Most cases the stock springs are fine and will not valve float.
Old Mar 26, 2009 | 01:55 PM
  #50
DSMer...'s Avatar
^^^Hey what do you mean by BR race core? Engine? Head? Cams? In your car that is.
Old Mar 26, 2009 | 02:23 PM
  #51
SRT-TO-EVO's Avatar
Intercooler I assume.
Old Mar 26, 2009 | 02:32 PM
  #52
shunderwunder's Avatar
I've got the FP4R's on my car but it's stock turbo still. The car made 349HP on a Dyno Dynamics dyno. I was told that they believe this is the most they have seen from a pump gas stock turbo on that dyno. Most full bolt on cars with cams are arround 330HP. I don't have any experience with Kelfords but these things are tons better than my old BC 272's. For what it's worth I love them.
Old Mar 26, 2009 | 02:35 PM
  #53
The FP4R's are made by Competition Cams for Forced Performance. So you know it's good quality.
Old Mar 26, 2009 | 10:19 PM
  #54
SRT-TO-EVO's Avatar
The cores supplied to FP, and now Kelford, are motivicity cores. Certainly not "made" by Comp (almost all cam companies have "blank" suppliers that they then grind to their own specs including Comp) Comp just grinds FP's cams to their specs.
Old Jun 7, 2009 | 11:52 PM
  #55
shuttlegoose's Avatar
not to bring this back from the dead but does anybody know if the fp4rs are readily available for the ix, i don't want to be on a 3 month waiting list like the people waiting for reds...
Old Jun 8, 2009 | 01:28 AM
  #56
EVO8URV8's Avatar
Kelfords are snapping on IXs like yours, not like VIIIs like mine.
Old Jun 11, 2009 | 01:12 AM
  #57
RickU's Avatar
how do kelford 272 cams compare with the cosworth M2s for the evo 9....
Old Jun 11, 2009 | 07:27 AM
  #58
bbyevo8u's Avatar
as far as what?? reliability - performance
Old Jun 11, 2009 | 11:52 AM
  #59
Erik@MIL.SPEC's Avatar
Based on specs, the GSC S2's, Kelford 272's and the Cosworth M2's are all in the same ballpark. However, no one here (that I know of) has put them on a cam doctor and gotten actual measurements off the cams.
So right now, most of this talk is conjecture.
Old Jun 11, 2009 | 11:56 AM
  #60
tim85851's Avatar
i read around here that kelfords on a green rock the hell out of any other cams...so my guess is that with a red it will be the same too.
