FP3065 - Evolution 3
Old Jan 20, 2009 | 06:35 PM
EvoIIIAj's Avatar
Hey guys I am going to be going with this turbo in about 2 months. I already have the FP race manifold and tial 44mm wastegate for it.
I was just wondering if you guys think it would bolt up just like this? I think this is a 2G eclipse which has the same engine as the Evo 3.
Old Jan 20, 2009 | 06:38 PM
vboy425's Avatar
wow very clean engine bay
Old Jan 20, 2009 | 06:44 PM
Bimmubishi's Avatar
Everything should be the same. I can't think of any major difference that would cause a problem in fitting it.
Old Jan 20, 2009 | 06:52 PM
EvoIIIAj's Avatar
Nice! Can't wait to get it.
Old Jan 20, 2009 | 06:58 PM
wreckleford's Avatar
The Evo has less space between the turbo and the radiator, but based on how FP has the wastegate angled to the side, it shouldn't be a problem. Also, the engine bay is narower so you wil have to use a shorter filter if you are using the FP intake.
Old Jan 20, 2009 | 07:00 PM
EvoIIIAj's Avatar
Yeh I know for sure between the turbo and radiator will clear, but it's just where the top of the wastegate sits what I wasn't sure about.
Old Jan 21, 2009 | 06:57 AM
94AWDcoupe's Avatar
I have evo 1. That turbo doesnt fit if you want to retain a radiator fan. I even use slimmer evo 8 fan. still wouldnt fit. I have a nice 3071 turbo kit with FP manifold 40mm tial , ceramic coated. just removed from evo1 so I could use evo 10 TS turbo setup on my car. It was a lot of work to make 3071 fit. it uses smaller E cover. getting S cover in there is gonna be tough. dont think it can be done with fan. I even moved radiotor off center to give more clearance between fan and turbo. In short these cars sucky for engine compartment space.
Old Jan 21, 2009 | 05:27 PM
EvoIIIAj's Avatar
I wasn't planning on keeping the big fan, I have a 14" slim fan.
Do you think I will be able to clear?
