what spark plugs?
Old Jan 21, 2009 | 05:21 PM
YNGEVO's Avatar
do these br8es need to be gapped or are they already pre-gapped correctly.
thanks guys
Old Jan 21, 2009 | 06:20 PM
YNGEVO's Avatar
Old Jan 21, 2009 | 06:25 PM
bluebanana23's Avatar
regap them, iridiums are pregapped
Old Jan 21, 2009 | 06:28 PM
YNGEVO's Avatar
anyone know what to gap them at..
Old Jan 21, 2009 | 07:12 PM
sparky's Avatar
Originally Posted by wevo1985
...with meth the br7es didnt have enough spark and would just cut out on me.
Incidentally, what did you have the sparkplug gap set at when you were getting this blowout on Meth?
Old Jan 21, 2009 | 07:16 PM
sparky's Avatar
They don't come uniformly gapped. So, don't just toss them in right out of the box. On pump gas and moderate boost levels(19-24#), I would try .024-.026 on the BR8ES's. But, on pumpgas I would only use this cold of a plug if the car sees mostly highspeed highway driving, with very limited idling and little stop and go driving. This is plug is fairly cold for a street plug on pumpgas, especially if the car is going to see a lot of stop and go driving. It may tend to load up. It is however, the preferred plug for Meth addicts with a tight gap for Meth.
The BPR8ES is a half step hotter than the BR8ES and may be a better choice for daily driving on pumpgas and moderate boost. I however would pick the BR7ES for street driving on pumpgas and moderate boost levels( up to 24PSI). The BR7ES is a half step colder than the stock heatrange and can be gapped a bit wider for pumpgas, than the BR8ES(Try .026-.028), depending on the type of driving that you do.
Old Jan 21, 2009 | 08:12 PM
wevo1985's Avatar
between .023 and .020
Old Jan 21, 2009 | 08:32 PM
nightwalker's Avatar
I'm running 22psi on 91 pump, and the plug that has performed the best for me is the BR7ES. On 22 and pump, you don't really need the 8 plugs. The non protruding plug runs smoother and stronger I've noticed than the regular BPR7ES.
I've also ran the NGK stocks, and Desno IW22s, and I prefer the BR7ES over them.
I have mine gapped at .024, using a feeler gauge. The circular plug gapping tool they sell at the auto store for .99 is garbage.
Old Jan 22, 2009 | 09:02 AM
YNGEVO's Avatar
i will also be running 25-28psi on race gas though. But thats only maybe 3 times a month.
Old Jan 22, 2009 | 04:02 PM
wevo1985's Avatar
as to why i say you need the colder, i dont think people read the whole post. what does your tuner say about it?
Old Feb 3, 2009 | 09:06 AM
adamweldonjohns's Avatar
Question for everybody,
I'm running BPR7ES's in my IX, but when I go on roadraceengineering's website, they say "only for evo 8." Anyone know why that is? Should I run out and buy something else before my engine blows up?
Old Feb 3, 2009 | 09:50 AM
mplspilot's Avatar
Yeah you should. It's not gonna blow up, but 8 plugs don't fit right in a 9.
Old Oct 26, 2009 | 04:56 PM
fugiwara's Avatar
EVO 8 plugs are different in length than EVO 9 plugs
Old Nov 25, 2009 | 08:22 PM
10isace's Avatar
BPR8ES NGK Copper plugs are amazing!!!
OK, I've reading all about which plugs to use and I am so happy for this forum!!! I added a few mods recently to the mods I already had and I noticed more power, but it was misfiring and knocking at WOT, so I avoided WOT. I just hit 60K (bought it with 30K) and decided to change the spark plugs. I'm so glad I did!!!
The idle is so much smoother and acceleration is amazing and I definitely gained power. I thought it was because I am now using the BPR8ES, but now I'm wondering if it is because my old NGK Iridium plugs were gapped at .040". I guess over time it widens. Anyhow, I'm just so much happier with my car!!!
Old Nov 25, 2009 | 09:18 PM
dambikeracer's Avatar
NGK Iridium IX's
yals
Pacific Northwest
Dec 10, 2013 02:32 PM
CrawlinTBSS
Dec 22, 2011 09:15 AM
rdv1212
09+ Ralliart Show and Shine
11
May 19, 2010 08:36 AM
YNGEVO
Feb 6, 2009 12:52 PM
playmajohn
May 25, 2008 04:34 PM
