Is it possible to tune evo 8 on 2 wheel drive dyno
Old Jan 22, 2009 | 12:00 AM
4g63tgt35r's Avatar
I will probably get roasted for this but a few shops told me you can tune it buy taking the drive shaft off another shop told me they raise the front wheel, I would think 4 wheel drive need 4 wheel dyno.
Old Jan 22, 2009 | 12:17 AM
idriveanevo's Avatar
wow, dont trust either shop... jack up the front? really??
Old Jan 22, 2009 | 12:19 AM
vicksen's Avatar
Sure you could try both those approaches. Should you? NO!!. Raising the front wheels would be very dangerous to your car, the person in the car, the equipment around the car, and if somehow it worked your readings wouldn't be accurate. Take the drive shaft off? Really? How much would the labor bill on that be? Also the same issue with accuracy. Both ideas are bad. The real question is which one is worse?
Four wheel dyno or none at all is my suggestion
Old Jan 22, 2009 | 12:20 AM
SPOOLEDTSiAWD's Avatar
just dyno on an awd dyno. its not worth the hassle to go around it. And its definitely not worth something happening to your especially jacking half of it up in the air to dyno it
Old Jan 22, 2009 | 12:22 AM
Evolution IVGSR's Avatar
Both shops shouldn't have a dyno if they are telling you that
Old Jan 22, 2009 | 01:29 AM
Zerokei's Avatar
That's a pretty interesting story they must of told you. I wouldn't trust either shop if they are telling you that.
Old Jan 22, 2009 | 01:46 AM
kaymin's Avatar
drop a couple towels in gasoline and throw them randomly around those shops.....
the WRONG things people will do for a little money....
don't forget to light the towels on fire
Old Jan 22, 2009 | 01:50 AM
SLO-EVO's Avatar
umm... please dont do that... it will be ALL BAD for your car... dont trust either shop like everyone said... i cant believe theyd feed you some BS like that....
Old Jan 22, 2009 | 02:01 AM
borievoinitialD's Avatar
lol...phack that... just save up and do a awd dyno...good luck, lmao at the towel on fire guy
Old Jan 22, 2009 | 02:03 AM
skatermsmn's Avatar
I remember on the dsm's, people would use a welded viscus coupling and convert it to 2wd on the dyno. I wouldnt want to do this.
Old Jan 22, 2009 | 03:31 AM
1NastyMR's Avatar
you got to be kidding me does that even make sense to you? why would you listen to such dumb people? raise the front wheels or disconnect drive shaft.....
Old Jan 22, 2009 | 05:11 AM
JakeTheVIII's Avatar
Don't do it. You will toast your t-case after a while.
https://www.evolutionm.net/forums/6594136-post5.html
Old Jan 22, 2009 | 05:34 AM
4g63tgt35r's Avatar
That is what I thought one of the shops has a 600hp evo they took the rear drive shaft to get its tune but I am way to scared to be doing that with my car. ****y thing for me is my car was tuned in the Washington area I bought it from a bank repo and brought it up to Winnipeg Manitoba Canada I have only been driving it around on low boost dont want to try high boost with out a proper wide band what do you guys think of just tunning on the street. There are no awd dyno here lots of 2 wheel drive dyno its all 600hp fwd hondas and muscle cars I think there is only 3 other evo in manitoba. hey mabey you guys have seen my car before I wish I could find the history on it I am sure it has a stroker motor.
link to my car and the mods it has
http://www.tyeeimports.com/Details.asp?ProductID=433#
Old Jan 22, 2009 | 05:37 AM
4g63tgt35r's Avatar
Thanks for the help my last car was a modded eclipse gst so the 4 wheel drive is all new to me.
Old Jan 22, 2009 | 05:44 AM
OhsixIXBish's Avatar
lmao at this thread..haha lol
