o2 housing
Old Jan 22, 2009 | 07:09 AM
Wick3d3vo9's Avatar
o2 housing
IF you port the stock o2 housing will you receive the same results as a ebay/works/invidia/megan racing o2 housing??
Old Jan 22, 2009 | 07:44 AM
Lumpskie's Avatar
I can't say for sure... but I've heard that the ported housings don't perform quite as well as aftermarket ones. I've seen a couple dyno sheets, but I can't be sure that it's actually the housing making the difference. That being said, I know that ported stock housings don't have the reliability problems that some aftermarket ones do. Sorry I can't be more help...
Old Jan 22, 2009 | 10:30 AM
sspaladin28's Avatar
The short answer is no and even BR has transitioned away from the ported stocker
Old Jan 22, 2009 | 10:54 AM
Wicked White's Avatar
I've done a lot of research on the best o2 housing, and I've come to the conclusion that the WORKS 76mm version is hands down the best when accompanied with they're downpipe. It's thermal coated to keep the heat in instead of radiating throughout your engine bay and your ACD (with the downpipe). Perfect setup, and costly. Also this system needs no modification to fit...
PSA
May 31, 2017 07:53 AM
EvoNyMR136
Apr 20, 2011 08:25 AM
Evo23IG
Nov 9, 2005 04:29 PM
aresix6
Sep 23, 2005 07:48 AM
500whp.com
Mar 6, 2005 06:30 PM
