bolt type
Old Jan 24, 2009 | 08:41 PM
Itchy's Avatar
bolt type
hey all, i was doing a turbo swap (evogreen) and got stuck along the ways.. i have everything basically ready but for the fact that i was unable to interchange the bolts coming off the exhaust manifold to the turbo itself, apparently there are 2 actual bolts and 2 of them have just the nuts that go into the manifold and turbo.. so wanted to know if anyone would know or be able to find out what size/pitch and everything this bolt was, so i could just hopefully run out and pick up some new ones from home depot or some sort.. thanks alot.. and before i go looking if any of you know what size the o2 sensor is off of the o2 housing that would be great thanks alot
Old Jan 24, 2009 | 09:24 PM
evokid511's Avatar
the size of the o2 sensor mean bolt pattern or size wrench you will need?? if your wondering th size wrench its a 22mm as for the bolt size im not sure
Old Jan 24, 2009 | 10:42 PM
Itchy's Avatar
yeah, with looking around a bit i actually ran across that as well, thanks.. but would anyone know the bolt size or stud size/pitch/depth of bolts/studs?
