Blown engine at 81k. Looking for Advice
Old Jan 28, 2009 | 07:55 AM
  #31
dave3kgt's Avatar
Originally Posted by althemean
These engines arent cheap thats for sure. Buying a used one...depends. If you could somehow get a compression test or leak down test prior to purchase that would give you the best picture of the engines health. If not, well....buyer beware I suppose. Just purchasing a used block to bore and rehone...no prob. The machine shop will take care of all the details and I would suggest lettign AMS, BR, Jam build your shortblock.
The timing belt and related parts you want to replace. You will want to replace the oil pump and water pump. Your oil cooler is suspect of being contaminated. You wouldnt want to install a new engine and then have metal from the old engine that was stuck in the cooler come out into your new bearings. That would be bad. Personally, I had metal in my engine. I did not replace the cooler. But I cleaned the hell out of it by sticking it onto a solvent tank pump, flowing solvent for hours, ran iso alcohol thru it, blew it out with shop air and repeated several times. I also poured all contents out thru a coffee filter to see if any particles came out. None ever did. Thats not always the case and I was advised against doing this but...I trust myself.
Something else, if you dont have a factory manual...get one. It lists all the torques and specs for putting the engine together and is invaluable. PM me if you have a hard time locating one. I can point you in the right direction.
JROD from Buchur said the same thing about the oil cooler, but I have had an aftermarket one sitting in my garage for a while, I just haven't bought oil lines yet. At least one of my problems is solved lol.
Old Jan 28, 2009 | 09:38 AM
  #32
Jrod@Buschur's Avatar
Let me know if there is anything else I can help with Dave.
Old Jan 28, 2009 | 09:40 AM
  #33
psphinx81's Avatar
buschur ftw! listen to my man jarrod :P
Old Jan 28, 2009 | 10:10 AM
  #34
dave3kgt's Avatar
I will my friend, don't worry.
Old Jan 29, 2009 | 12:19 AM
  #35
j3ffw19's Avatar
Jam has a complete stock short block for 2700, since your on a budget that would make alittle more sense. Who knows if you need head work or not, and besides you could buy the wife something to make her forget about this little set back..
https://www.jacksonautomachine.com/h...m?sectionId=31
Old Jan 29, 2009 | 07:37 AM
  #36
althemean's Avatar
^^there ya go
Old Jan 29, 2009 | 10:18 AM
  #37
dave3kgt's Avatar
Good advice indeed...
Old Jan 29, 2009 | 11:38 AM
  #38
2006blkevo9's Avatar
When my engine blew up I ordered one from Lancershop.com... When it was on sale I got it for $4750.00 A year ago or so. Crate motor with turbo.. Installed, started right up, I sold the turbo and some other parts and bought my a ring for the wife....
Old Jan 29, 2009 | 01:00 PM
  #39
mywht03's Avatar
im in the process now of buying a stock oem block after i spun a rod bearing. found out it hit the crankshaft. since it comes with everything im taking that cheaper way out.
Old Feb 13, 2009 | 12:20 PM
  #40
dave3kgt's Avatar
UPDATE:: I sold the wife's old car today, and I will be starting to order parts next tuesday. Finally!!! Also, I will post up some pics of the old engine and the damage. I got the head off the other day to discover that I have no piston left in cyllinder 3 and the hole is thorugh both sides of the block. Talk about boom... Pics coming soon.
Old Feb 13, 2009 | 01:06 PM
  #41
Let me know if there is anything I can do to help Dave.
Old Feb 13, 2009 | 01:23 PM
  #42
DIDYSIS's Avatar
Make sure you replace the Oil cooler, Lifters, any and all oil lines, coolant also because I am sure it all mixed. been there done it, almost all fixed now
Old Feb 13, 2009 | 01:27 PM
  #43
1badmr's Avatar
Originally Posted by 2003lancerevo8
Here is the link to the 2.3RR Motor
http://www.amsperformance.com/cart/p...cat=292&page=1
I know this would be my first option if I had a choice in motors.... This thing is crazy strong
yeah i feel you on that strong price also maybe i can refi my house and get one lol
Old Feb 13, 2009 | 02:55 PM
  #44
blkmkIII's Avatar
i vote stock motor head studs and spacer.. save your $
Old Feb 18, 2009 | 01:37 PM
  #45
dave3kgt's Avatar
Looking at buying a stock Evo IX longblock and going from there. I will try to get the pics up tonight if my internet at home is working.
