NEED HELP: unstall turbo kit new one on!
Old Jan 31, 2009 | 02:52 PM
evoracingstar's Avatar
well im in the middle of uninstalling my Bushcur gt 35r turbo kit and i put it on my self but i forgot how to get the 3 bolts under neath the manifold! its such a pain in the @$$. can anyone give me an suggestions on a easy way of doing this it would be great thanks alot!!
Old Jan 31, 2009 | 02:59 PM
bump in the middle of it now need help need this off tonight lol
Old Jan 31, 2009 | 07:04 PM
850RCT9A's Avatar
You mean nuts on the bottom of the manifold??? Simple wrench should be sufficient. Come in from the sides and take your time. Maybe a flexible gear wrench will speed things up.
Old Jan 31, 2009 | 07:12 PM
def1's Avatar
the middle one use a ratchet and regular socket. The one on the right use a ratchet and a deep socket 14 mill. The one on the right use a really long extension maybe even two and a 14 mill and get to it from behind the manifold
Old Jan 31, 2009 | 07:19 PM
heel2toe's Avatar
All I can tell you is that its all about having the right tools. It may only be possible to remove them with a wrench or if you have some gear wrenched that would be even better assuming they fit. That will be my next tool purchase for sure. I cant think of how many times I wish I had gear wrenches. But if I remember correctly I was able to squeeze in a socket for almost if not all of the muts on my factory manifold. Oh and I am assuming you are talking about where it meets with the head as opposed to the O2 housing?
Old Jan 31, 2009 | 07:20 PM
MattyBoyMR's Avatar
they are 12mm not 14mm the 14mm are the 2 ends on the bottom but just take your time and be patiant try from diff angles lol
JMB8606
Jul 17, 2006 02:21 AM
3000ways
23
Mar 9, 2006 01:12 PM
Ryan Bush
Lancer Aftermarket Forced Induction Tech
152
Apr 4, 2005 12:52 PM
BSREVOLUTION
13
Aug 17, 2004 12:07 PM
hondacbr
11
Apr 14, 2003 07:33 PM
