open dump for stock turbo
Old Feb 5, 2009 | 08:38 PM
Itchy's Avatar
i had a question for you people that are running the epm dump pipe, from my understanding, the exhaust gasses are only going to be routed through the dump pipe when under boost ~15 pounds.. after i installed it, i noticed that exhaust gasses are constantly flowing through it even at idle.. wanted to know if this was normal, or if exhaust gasses are sneaking their way out the dump pipe because i ended up using the o2 gasket provided by the 9 install kit
Old Feb 5, 2009 | 09:36 PM
Q@EvoPowerMods's Avatar
You've got the wrong gasket on there. We provided a gasket with every order. The gasket you used was not divided hence the huffing at idle. Change out the gasket to the one we supply and you'll be fine. Give me a call if you more info or help.....
Old Feb 5, 2009 | 10:23 PM
jxs1984's Avatar
maperformance have one as well. stay away from qtp!
Old Feb 5, 2009 | 10:40 PM
markymark1082's Avatar
Go with EPM : http://evopowermods.com/ I have one that is about to go on my Red.
Old Feb 5, 2009 | 11:20 PM
Itchy's Avatar
any ill effect if i didnt use the one provided (minus the lightheadedness when driving haha) now to think about it i shouldnt be loosing any extra ponies or anything like that, maybe just have less backpressure causing a later spool?
Old Feb 6, 2009 | 10:17 AM
C6C6CH3vo's Avatar
Originally Posted by Q@EvoPowerMods
I'll be more than willing to talk about our EPM O2 Dump.
Q,
With WBO2 installed several feet downstream the main exhaust portion of the O2 dump, have you seen any reports of skewed AFR readings when WG opens? What about drawing O2 in the dump back up through WG and out the scrolls at cruise showing higher than normal O2?
I expect a leaning event compared to w/o dump from lower pressures behind turbine, just wondering what to expect otherwise.
This is a part I'm really considering.
Thank you
Old Feb 6, 2009 | 01:55 PM
TouringBubble's Avatar
The O2 sensor (stock and WB) measure O2 content, not volume. O2 content in the exhaust flow isn't affected with the dump open ... the volume is simply reduced (split). I have seen no changes in readings. The front O2 responds normally in closed loop and the WB matches it.
AFRs didn't change much for me after the install. Maybe a max of .2 difference up top in a small range, but I was also in a different load cell so that's inconclusive. It was dead on my previous logs under 6000. I run ECU boost control, so the boost response was constant before and after the install which gave us a nice AFR comparison.
At a cruise state the WG actuator sees vacuum and the puck is closed. There should be no notable amount of ambient air entering the exhaust flow if the correct gasket is used. If the WG sees enough pressure to open, then ambient air isn't being pulled in to the turbo ... it's being pushed out. Again, front O2 readings are normal and fuel trims are in check.
I hope that answers your questions.
Old Feb 6, 2009 | 01:59 PM
See above. At cruise, the front O2 could see an artificially lean mix and add fuel, reducing fuel economy. I haven't tested it though ... just a possibility.
Old Feb 6, 2009 | 02:34 PM
David24's Avatar
I don't know if this has already been answered but does the EPM affect emissions? Will it fail?
Old Feb 6, 2009 | 03:51 PM
FL_SilverEvo8's Avatar
mike@AWD Motorsports has them.
http://www.awdmotorsports.com/
Old Feb 6, 2009 | 03:53 PM
griffeyr's Avatar
Hey man, i'm runnin the epm 02 dump on my red turbo and love it...Also, you can't beat the customer service...q is top notch..epm ftw
Old Feb 6, 2009 | 06:37 PM
C6C6CH3vo's Avatar
WBO2 is very sensitive to partial pressure, thats how it measures how rich it is from the amount of O2 it has to pump toat partial psi of stoich, when the WG opens the pressure on the sensor would drop.
Old Feb 6, 2009 | 06:49 PM
URBANRCR's Avatar
Go with EPM!
Old Feb 6, 2009 | 07:19 PM
Wicked E's Avatar
I got the last Version 2 from him on Tuesday.
-E
Old Feb 17, 2010 | 12:06 PM
bizaarhatch's Avatar
I cant get a price or nuthing on the epm site?? I would buy 1 today if the price is rite
