Who Is a good tech starting issue Evo 8
Old Feb 8, 2009 | 12:25 PM
EVO9MRNJ's Avatar
Did a forum search looking for more info.. Please help me out fellow evo tech's.
Real simple... 03 VIII turn key no cranking...
Put key in ignition, Have power, batt voltage, and fuel, turn the key and NOTHING at all. Fuses look good, just get nothing when you turn the key like you would if you turned the key and your foot was not on the clutch.
crank angle sensor?
cam angle sensor?
Who has the answer???
Thanks
steve
Old Feb 8, 2009 | 01:08 PM
josh prochaska's Avatar
have u tested the starter to see if it works.
Old Feb 8, 2009 | 01:49 PM
IEXCELR8's Avatar
did you just install anything? As you mentioned (cas,cps) could be any of those or the starter, check the switch for the clutch for damage.
Old Feb 8, 2009 | 07:11 PM
EVO9MRNJ's Avatar
It was the starter signal wire. Thanks guys
