Cosworth M2 VS Kelfords 272/272
Kelford manufactuers the Cosworths and their specs are nearly identical. If I recall correctly, the Cosworths are actually slightly more aggressive with a longer duration @ 1mm (they have the same duration at .1mm). I spent quite a bit of time studying the available IX MIVEC cams and ended up with the FP4R's. My friend has the Kelford 272's on his IX and his idle/drivability is noticeably better than mine.
I recently got the kelford 272s installed (stock springs retainers) havent tuned it yet, probably this weekend. My other friend has the basically the same set-up as me apart from the 02 dump( I have a megan 02) and M2s. And he made 451/435 i believe. I will post up results once I get tuned.
