EVO IX STOCK BOV fluttering
Old Feb 12, 2009 | 04:12 PM
coolguyuno1's Avatar
Question EVO IX STOCK BOV fluttering
I just put in an AMS intercooler and full Injen piping with intake. Now the BOV makes a fluttering sound and me and my buddie can figure out what to do. The swoosh sound is no longer there, it sounds more like: http://www.youtube.com/watch?v=_mYZROSXpAw
and it is louder than before. This is a stock IX GSR BOV, running at stock boost, checked for boost leaks also, even change the vacuum hosing multiple times!
Thanks in advance everyone!!
Old Feb 12, 2009 | 04:14 PM
apagan01's Avatar
the injen kit for some reason did it for me, flutter with stock and with a brand new forge rs, partial throttle flutter.
what worked for me is 41 clicks, this is on stock evoix turbo, @26 lbs
Old Feb 12, 2009 | 04:19 PM
It flutters with high or low boost at high or low RPM, flutters when I let off gas, what do you mean by 41 clicks?
Old Feb 12, 2009 | 04:27 PM
Steve93Talon's Avatar
Did you re-install it backwards? The end that's mounted to the flange with 3 phillips screws should be on the charge piping side.
Old Feb 12, 2009 | 04:48 PM
My friend says he doesnt know hahahha
Old Feb 12, 2009 | 04:49 PM
any pics?
Old Feb 12, 2009 | 04:53 PM
ev0lution9's Avatar
i have the same kit it flutters when i give it a good amount of gas and then let off
Old Feb 12, 2009 | 04:55 PM
So is it nothing to worry about then? I just dont wanna have turbo problems down the road, my friend freaking out to haha
Old Feb 12, 2009 | 05:00 PM
apagan01's Avatar
completely normal.
listen to any big build like BR, most wanted, AMS,, when they do quick burnouts before the stage line,, when they press the clutch you can hear them flutter.
nothing to worry about, just watch compressor surge now thats bad,, and you can search that on youtube and get an idea of what it sounds like that way you know what to troubleshoot if it happend one day
Old Feb 12, 2009 | 05:03 PM
ev0lution9's Avatar
yeaa dont worry about it man i got the same kit its just alot more open now that you dont have an air box if its when you let off the gas your fine if your boost is getting cut off or not hitting the psi your set at then you have a problem
Old Feb 12, 2009 | 05:20 PM
yeah me and my friend turned it up to 22 psi, spikes at 24 holds 22-23! It fluttered at 14 PSI also. I youtubed compressor surge, and my car does sound like this: http://www.youtube.com/watch?v=LZUbo...eature=related
maybe the video is BS though, I hope so!
Old Feb 12, 2009 | 05:24 PM
jxs1984's Avatar
my stock plastic dv flutters under partial throttle. are you sure you have the dv set up the right way?
Old Feb 12, 2009 | 05:32 PM
Not sure, my friend did everything, have pics for that? what is a DV?
Old Feb 12, 2009 | 05:44 PM
I keep reading things about how bad this is for the turbo haha, any other input?
Old Feb 12, 2009 | 06:23 PM
AznDragonV's Avatar
i have a forge rs with the injen. at first i was freaked out.. but i asked my tuner and he said its normal. does it flutter at high boost? and high RPM?
