New starter new battery,,,Still click click
Old Feb 12, 2009 | 11:44 PM
ant_turbo's Avatar
My starter went out then replaced it then found out my battery wasn't putting
out enough cranking amps so I replace the new battery,,,,
Still having same issues,,, When I go to start it all you hear is click click..
no turning over just click click..And if I turn the Ignition on off on off a few times it will start up...What do you guys think it can be,,, Checked all wires and cables from the starter the the battery,,,,
Old Feb 12, 2009 | 11:53 PM
whoang40's Avatar
Pull your back seat out and see if you hear the fuel pump whining. Do you have any mods?
Old Feb 13, 2009 | 12:01 AM
ant_turbo's Avatar
So do this while the Ignition is off or on??? As for mods I have just ur basic mods
boltons... But I do have a a walbro....
Old Feb 13, 2009 | 12:15 AM
whoang40's Avatar
Do it while you have the ignition on. You should hear the pump prime before the starter cranks.
Old Feb 13, 2009 | 12:19 AM
sikrsix's Avatar
^^^ Waste of time!!! It doesn't turn over it, so it has nothing to do with a fuel pump. Sounds like the starter is jamming up. When you try to start it and it clicks, put it in 1st gear and rock thee car hard back and forth a couple times. If it starts then you have a starter gear/flywheel issue.
Old Feb 13, 2009 | 12:29 AM
whoang40's Avatar
But I do agree it could be the starter. You could also pull out the starter and have it checked free at Autozone. Checking the noise of the fuel pump is not a waste of time, just easier to pull out the back seat, listen, then pulling out the starter
Old Feb 13, 2009 | 12:42 AM
TIBOevo's Avatar
maybe a bad ignition switch?. its hard to say without being there. get starter tested. make sure wire harness for starter is hooked up right.
Old Feb 13, 2009 | 12:47 AM
02-Lancer-Es's Avatar
I would try powering it directly from the battery before taking it off to see if it is a electrical problem like the ignition switch . From the positive on the starter to the positive on the battery . I have also heard of weak grounds causing this problem .
Old Feb 13, 2009 | 05:04 AM
TIBOevo's Avatar
yes, i had the same ,well maybe the same problem as you. i had the starter checked . it was fine, checked all the fuses . they were fine. then i openned up the steering column. i had too wiggle my keys around sometimes to get it too start. ok heres what i did here. i noticed when i pushed on the back of the ignition switch while i turned the key, the car fired up. then i realized that when i didnt push inn on the switch while starting it was arcing inside the switch was shooting sparks. replaced it then bam the car was good for a couple weeks. then something else happened the car wouldnt start. just click click. had it towed home. found out that it was the big ground on the starter wiring harness. the one that is bolted to the bell housing on the block, it came loose. so i hooked it back up then presto. the car starts everytime. no problems for months now. so it could be a combination of things?. look hard bro and youll find your problem. check your ignition switch. do you have a lot of stuff hanging from your key chain?
Old Feb 13, 2009 | 05:38 AM
sk8terdude929's Avatar
the fuel pump will not stop the car from cranking, no matter how good or bad the pump is. Try to jump the starter straight from the battery if it doesnt start then, pull the starter back out and check to make sure the arm is comming out of the starter and the teeth are not all chewed up. I agree with it being a flywheel to starter issue, if not an electrical problem within the ignition
Old Feb 13, 2009 | 06:10 AM
apagan01's Avatar
check simple stuff like fuses,,, sounds simple but it could be as simple as that.
Old Feb 13, 2009 | 07:44 AM
VRSF Tiago's Avatar
You could have a parasitic drain that could have drained your battery if after you replaced it. Try jump starting the car and see what happens.
Sounds relatively easy and if you hear the tick tick that's the starter telling you it's not getting enough power to crank.
Old Feb 13, 2009 | 08:33 AM
20gmr's Avatar
I think this guy has it. if it works after cycling the key could be a bad switch. unplug the small wire with black clip at the end by the starter and check for voltage when someone turns the key for you
Old Feb 13, 2009 | 11:16 AM
ant_turbo's Avatar
Thanks guys.... I well recheck the new battery maybe I do have a drain on the
battery...
Old Feb 13, 2009 | 11:20 AM
oneonlywgs's Avatar
Good write up. I'll have to keep this in mind since I have an 03 also. Nice job.
