Blown front or center differential???
Old Feb 18, 2009 | 04:11 PM
deuce329's Avatar
My car has essentially turned into front wheel drive. There is no power going to the rear wheels. When i punch the gas in boost it wheel hops and shakes the entire front of the car. It drives fine out of boost but feels front wheel drive.
Does the Front Diff have to be changed or the center diff or both? The car has a built shep stage 2 transfercase with stock differentials. I have done no hard launches recently either.
Old Feb 18, 2009 | 04:21 PM
project VII's Avatar
not center diff because the car wouldn't be able to drive at all. most likely its the rear diff in your tranny. i'm going through the same problem actually lol i'll find out more this weekend when the tranny get pull
Old Feb 18, 2009 | 04:24 PM
JdMeVo4's Avatar
A buddy of mines car did a similar thing the viscous coupler siezed up over heated the center diff bearings and cracked the transfer case housing almost in half. It would bind up and stop out of no where. We though he may have had water in his brake lines causing the stopping out of no where problem then it popped and we found the problem lol.
Old Feb 18, 2009 | 11:34 PM
deuce329's Avatar
So your saying its not the front diff inside the transfercase either???
Old Feb 18, 2009 | 11:39 PM
vboy425's Avatar
if your transfer case was fk, you wouldn't be able to drive period. have your rear diff check out.
son of krypton
41
Jul 27, 2022 11:35 AM
Mauricio Evo IV
Mar 2, 2016 12:29 PM
740 Turbo Brick
Jan 6, 2016 08:22 PM
DSPORT
Aug 26, 2015 12:24 PM
