ix wanting to stall on 1st gear and reverse
having a little issue when starting off into 1st gear (or reverse), the ix bucks a bit and wants to stall. been letting off of the accelerator later (gassing it a bit) so it wouldn't happen too much but does not eliminate the issue.
not sure if the following contributes to it:
- works dropin filter
- works dp
- works hi-flow cat
- junbl catback exhaust
no other modifications on the car.
guessing that it could be the clutch or fluid, but wanted to know if anyone has had a similar experience and how they were able to resolve the issue.
thanks,
-renan
- works dp
- works hi-flow cat
thanks,
-renan
