will these injectors work?
Old Feb 24, 2009 | 09:48 PM
v-manracing's Avatar
my brother got a 1st gen talon and the guy included lots of spare parts including a set of RC 750cc injectors.
will these work on my evo? does anyone know? Also will I see gains if I install them with my mods? I just have basic boltons and a EBC, boosting 22 PSI
Old Feb 24, 2009 | 10:59 PM
scheides's Avatar
EvoM Moderator
Yes they will, make sure you get fresh seals for them and maybe get them cleaned
Just putting in injectors (and tuning them) will not add power by itself, unless you were maxed out on your fuel setup in the first place, then you will be able to turn up zee boost
Old Feb 24, 2009 | 11:33 PM
DIDYSIS's Avatar
Yep they are good to go, as said check out the seals and set them up as needed.
Old Feb 25, 2009 | 03:06 PM
thanks for the replies guys
Old Feb 25, 2009 | 04:30 PM
chaotichoax's Avatar
as scheides said, unless you are out of fuel
larger injectors aren't going to make you any more power
Old Feb 25, 2009 | 05:10 PM
Kracka's Avatar
If anything, runner larger injectors when you don't need them will cause you to lose power and add starting/idle/drivability issues. The stock injectors have a great spray pattern so stick with them as long as you're able to.
