T-case Failure?? Please help!!
Old Feb 25, 2009 | 12:01 PM
Turbo-In-Use's Avatar
I have been trying to solve this mystery now for a while now that I have a source of income.
I have a problem that I show/tell people that they cant put their finger on it.
Here's the story.
Started moving from a stop light. Barely in boost. I shift from 1st to 2nd. When I let off the clutch the car made a noise (Please dont ask what the noise was. I dont remember) Then rolled to a complete stop. I thought to myself "Ok. Maybe it just popped out of gear." Well when put back into gear, the car doesn't move. AT ALL. But it makes a whine noise. Every gear gets a little louder. From 1st to 5th. Reverse wont work either.
So here is what happens...
I start the car. Wait for a couple of mins. Put car into gear. Let off clutch. The car makes a whine noise. WILL NOT MOVE WHEN IN GEAR. But I am able to move it around with the E-Brake off and the power of my legs.
I just put a new ACT clutch in thinking it may have been the problem. Its not the clutch.
My next guess is the Transfer Case is shot. I just need some opinions.
Please comment. Thank you!!
Old Feb 25, 2009 | 12:24 PM
Ev0ikon's Avatar
Are you sure your throw-out-bearing is engaged?
Old Feb 25, 2009 | 12:35 PM
EvoHung's Avatar
Check your fork to see if it broke. It could be your transfer case and it could also be your differentials. How about your shifter cables? have you checked to see if it is bent or anything?
Old Feb 27, 2009 | 02:16 PM
studdlywubbly's Avatar
mine was doing the exact same thing so i took it to the dealership they said it was the transfer case
Old Feb 27, 2009 | 02:23 PM
PVD04's Avatar
It could be either your transfer case or transmission. Something broke between the transmission output shaft and the wheels. Could be your center diff, could be the output shaft, could be anything else in between. Until you take it apart you aren't going to know for sure.
Old Feb 27, 2009 | 02:26 PM
Curt@MrLed's Avatar
Former Vendor
That is the only advice you should adhere too.
