No more CEL's with BR exhausts...
Old Sep 20, 2003 | 11:00 AM
David Buschur's Avatar
We have the problem fixed. Finally!!
We are not going to offer an 02 simulator for the car. We had no luck in making them work. Anyone that bought one and it doesn't work can return it for a full refund.
We do however have the problem fixed. We are now proudly offering the systems and they have NO CEL problems.
The new systems will cost the same money as the old. For those of you that want to send in your catback pipe I can make the changes to the pipe for $40. I am sure that most of you don't want to do that. I am also offering an updated "mid pipe" for $70 with the change in it.
As always, the best way around getting a check engine light is to just run the high flow 3" cat, this is emmision legal and eliminates the problems.
Thanks alot, hope this helps.
David Buschur
www.buschurracing.com
Old Sep 20, 2003 | 11:13 AM
mrdecibel's Avatar
David,
Will the mid pipe decrease any sound the exhaust currently emits? I had to opt for the hi-flow cat due to the sound being a little too "Aggressive" with just the test pipe.
Old Sep 20, 2003 | 01:19 PM
umiami80's Avatar
How was this done????
Old Sep 20, 2003 | 03:47 PM
BeenWaitin4Evo's Avatar
Slightly on topic, yet off!
A question about your 3' Downpipe for the Evo...
I noticed it doesn't have a "flex" section. Is this something this car should have? What does a "flex" section provide (I assumed noise dampening from the engine)?
Old Sep 20, 2003 | 06:35 PM
mrdecibel's Avatar
The stock doesn't have a flex section either. Not needed. However, the stock has a suspension system on the connection between the turbo outlet.
Old Sep 21, 2003 | 12:55 AM
w2pac12345's Avatar
David, I had a custom made exhaust and I get a CEL can I buy your midesection and will you still garauntee no CEL or do you wanna tell me what you did to prevent the light??
Old Sep 21, 2003 | 12:30 PM
boostedwrx's Avatar
More than likely he just placed the o2 sensor out of the exhaust stream, duh.
Old Sep 21, 2003 | 12:43 PM
MalibuJack's Avatar
Its still got to be partially in the exhaust stream otherwise it would still trigger a CEL due to the how the computer measures the difference in voltage between the two O2 sensors.. and if one sensor is disconnected or "Flatlined" at the same voltage, it will trigger a CEL For a malfunctioning sensor.. My best guess (because I did this on my neon) is that the bung is welded in at an angle away from the front of the car, and possibly a small shroud around the forward area of the sensor so it doesnt get exhaust directly onto the sensor, but it only gets wafts of it thereby showing a different value.
Old Sep 21, 2003 | 01:04 PM
boostedwrx's Avatar
i meant just sectioned away from the exhaust fumes such that all of them wont be hitting to o2. You are correct Jack, I had that done on my old GST also..
Old Sep 21, 2003 | 02:07 PM
SAEVO's Avatar
that is how he BR exhaust is, the o2 bung is actually welded onto the outside of the exhaust pipe and there is a small hole drilled into it so that it only reads some of the exhaust gasses going by.
Old Sep 21, 2003 | 09:27 PM
umiami80's Avatar
So this works all the time 100$ or just some of the cars, some of the time????
Old Sep 22, 2003 | 05:36 AM
The mid pipe is the offroad pipe. New name, same part. Don't ask what the name change was for
We have put about 500 miles on our EVO now and have no CEL light. The parts we had machined to do this is the largest reason behind the cost of fixing or supplying the new pieces to the guys that have already bought our systems.
There will be no difference in the sound of the exhaust with this compared to the offroad pipe.
David Buschur
Old Sep 27, 2003 | 06:37 PM
GTVEVO's Avatar
David I just recieved my Trubo back exhaust for my evo and I put it on Fridaynight, within a few miles I am getting a cell. I was told on the phone that I shouldn't have a cell light so what can I do to get rid of this?
Old Sep 27, 2003 | 06:40 PM
GTVEVO's Avatar
ON a side note my midpipe is just straight pipe , nothing in it and not shaped differently. Hopefully this info helps.
Old Oct 1, 2003 | 10:04 AM
Give the shop a call and let's verify you got one of the new systems, we just started doing this.
David Buschur
