Need help!!!!
Old Mar 1, 2009 | 06:01 PM
mr.built block's Avatar
Need help!!!!
Well heres the deal i decided to put my intercooler and piping on this weekend ,went and test drove it and no piping blew off. The check engine light came on for p0121 throttle position sensor A circut range performance problem,and the idle is surging. So i come on here and searched it found a few good threads, checked the piping all of my clamps were tight intake was tight no vacume leaks. I started the car and unpluged the TPS and the idle changed so I dont think thats what the problem is. let me know if you have any ideas
Old Mar 2, 2009 | 03:17 AM
bump anyone know?
Old Mar 2, 2009 | 06:16 AM
Mr. Evo IX's Avatar
Did you unplug the MAF without resetting the ECU? Try removing the battery terminal to see if your code goes away. Alternatly you can remove the fuse under the hood for the ECU.
Old Mar 2, 2009 | 06:27 AM
monkey_187's Avatar
^^^I would try that, unplugging the batt usually helps....
Old Mar 2, 2009 | 07:20 AM
yep reset ecu and took battery cables completly off to reset it too..
Old Mar 2, 2009 | 07:32 AM
Mr. Evo IX's Avatar
Unplug and replug in the MAF sensor and reset the ECU again.
Old Mar 2, 2009 | 09:55 AM
well just done that at lunch same idle!!!
Old Mar 3, 2009 | 03:23 AM
bump any more ideas
Old Mar 3, 2009 | 04:20 AM
oneonlywgs's Avatar
it's the throttle sensor.
Old Mar 3, 2009 | 07:21 AM
so i need a new TPS?
Old Mar 4, 2009 | 03:17 AM
bump any more tests before i go buy a TPS
Old Mar 6, 2009 | 03:14 AM
well tested the TPS with the dmm and it has good restiance so the sensor itself isnt bad...any other ideas?
Old Mar 6, 2009 | 03:46 AM
sparky's Avatar
Were you running the Tial BOV before the problem started?
Old Mar 6, 2009 | 05:10 PM
nope the stock one!!!!
Old Mar 6, 2009 | 06:37 PM
Trader Vic CT9A's Avatar
Have you done a boost leak test?
