new mods, no boost??
Old Mar 9, 2009 | 12:58 AM
eponti's Avatar
Follow the instruction above coz u hooked it up wrong. The bottom of the mbc needs to go to a vacuum source.
Old Mar 9, 2009 | 01:02 AM
mnr12's Avatar
Ok, I'll give it a try first thing in the morning. Hope it works!
Old Mar 9, 2009 | 01:04 AM
eponti's Avatar
Let us know what happened.
Old Mar 9, 2009 | 11:44 AM
epson1's Avatar
...it bogs because of a boost leak.
Old Mar 9, 2009 | 11:45 AM
mnr12's Avatar
Rerouted the BC to the intake/bov line, still the same results except now the car stalls after a few seconds of putting it in 2nd.
Old Mar 9, 2009 | 11:53 AM
05blue8's Avatar
You said you capped the wastegate actuator, then one sentence later you said yout put the line from the side to the wastegate...which is it? Something didn't get hooked up right. You have thousands of people on this forum who have used the diagram provided with the same good result. Something is loose or it's connected backwards. Did you do the boost leak test?
Old Mar 9, 2009 | 11:56 AM
mnr12's Avatar
I capped the turbo waste gate actuator, and fed the new line from the waste gate itself to the side of the bc.
Old Mar 9, 2009 | 12:03 PM
mnr12's Avatar
I just took out the mbc and reconnected all the lines, still bogs when attempting to get any boost.
Old Mar 9, 2009 | 12:06 PM
PVD04's Avatar
You are describing all the symptoms of a major boost leak, but keep saying you don't have a boost leak. Did you actually check? If your car is stalling and building no boost at all, it has nothing to do with the MBC. Also, the waste gate actuator is the part you have your MBC connected to. The thing you capped is called the boost control solenoid.
Do a boost leak check. Fix the leak. Drive car. Have fun.
Old Mar 9, 2009 | 12:10 PM
PVD04's Avatar
Originally Posted by SixOneNine
Make sure the MAF is plugged in. Did you hook up the mbc like this?
This is a bit confusing because the part labeled as "Turbo Wastegate Actuator" is actually the boost control solenoid. Also, there is absolutely nothing wrong with connecting the bottom of the MBC to the turbo and the side to the WGA. I actually prefer this method as it reduces the possibility of the MBC interfering with the proper function of the BOV.
Old Mar 9, 2009 | 12:58 PM
evokid511's Avatar
yeah gonna agree with everyone else heres sounds like a bpst leak... could be a tiny one that you cant see or hear tghough
Old Mar 9, 2009 | 01:01 PM
evokid511's Avatar
here is another post on MBC installs if your is done thois way then you no its not that... https://www.evolutionm.net/forums/ev...procedure.html
Old Mar 9, 2009 | 01:19 PM
100%STEALTH's Avatar
yeh i agree sounds like a boost leak
Old Mar 9, 2009 | 01:30 PM
andrewzaragoza's Avatar
if there is a thump at wot probably around 4k-5k then you are probably hitting your boost cut. you have to raise it so that you will not hit boost cut. also you would probably need to change your halman mbc spring to the stiff spring which should be included there.
Old Mar 9, 2009 | 07:05 PM
mnr12's Avatar
Just did a home made boost test, and if I did it correctly there is no boost leak.
