How Much Fluid??
Old Sep 22, 2003 | 11:31 AM
stevEVO8's Avatar
How Much Fluid??
Im getting ready to purchase the fluid for the tranny and the center and rear diffs...
How much fluid is required?
I read before that it would take 4qts for the tranny and .5 qts for both the center and rear diffs...
Is this right?
Right now im ready to prder 4qt MT90 for the tranny and 1qt of 75w90 for both the center and rear diffs.
From the people that have done this before Should I get another qt for the center and rear diffs or should the one be fine for both?
What about the tranny do i need any more than 4qts?
Thanks
Old Sep 22, 2003 | 11:52 AM
chinalfr's Avatar
tranny is 3 qts.
front diff is 0.5 qt
rear diff is 0.5 qt
get a qt more just for failsafe.
Old Sep 22, 2003 | 01:17 PM
stevEVO8's Avatar
Thanks Ill do just that.
Old Sep 22, 2003 | 01:24 PM
webguy330i's Avatar
https://www.evolutionm.net/forums/sh...t=fluid+change
I'm doing this next weekend @ ~ 2500 miles.
Old Sep 22, 2003 | 01:28 PM
iodine23's Avatar
3 quarts should be plenty for the trans, it only specs to 2.7qts I think. 1 quart is not enough for the transfer and rear diff. I think they call for like 0.57 quarts. Get 2 quarts just to be safe, that's what I did.
I ended up pumping about 0.7qts or so into each one and letting the excess drain out, just to make sure I had a complete fill.
