My Build project (Sort of build) Fp Red etc. Input Appreciated.
Old Mar 17, 2009 | 04:33 PM
Daryl Nilsen's Avatar
Il be running 93 pump gas, so it sounds like the 880s are going to be it. Wayne, il give you a call later on this week about the injectors, probably thursday. Thanks for all the input, Daryl.
Old Mar 24, 2009 | 02:27 PM
I received my Comp Springs today and had a question. The Sticker says they are for a Nissan SR20DE and i was unsure if they were going to work. The Specs are as follows:
SEAT LOAD: 75 lbs @ 1.550"
OPEN: 195 lbs @ 1.050"
SPRING RATE: 240 lbs/in
COIL BIND: .917
and the part Number is 909-16
I was told that these would work but i just wanted to make sure before i put them in, Thanks alot, Daryl.
- Also, I will no longer be running stock head bolts, the head is going to be pulled and arp's installed.
Old May 10, 2009 | 04:32 PM
Updated with results.
