wiseco .20 piston pin
Old Mar 18, 2009 | 03:01 PM
Gary@MellonRacing's Avatar
anyone know where i can get a wiseco piston pin , is it special or can i use a stock bore piston pin for the .20 pistons ???
Old Mar 30, 2009 | 12:54 PM
SeanC's Avatar
The wrist pin of a STD bore and +.020" should be the same. Just call Wiseco and order a single pin if you need one. If you find out what pin the kit normally comes with, you can verify you have the correct pin. Measure the pin diameter (should be 22mm), length and wall thickness.
Old Apr 4, 2009 | 08:52 AM
thanks , done
