Stock Fuel Pressure in a 04 evo 8?
Approx 38.5 psi base pressure with the vacuum line disconnected from the FPR at idle. If you are adding an adjustable FPR, most guys set it at 43-43.5 psi base pressure at idle with the vacuum line disconnected.
Josh
Josh
The original answer post was wrong. Base pressure for the 04 Evo 8 is 43.5. You set the adjustable FPR to 43.5 while vacuum hose is disconnected. Then you reattach the hose, and it should drop the gauge down to approx 39 psi. Just an FYI.
Jovan Caro
Feb 6, 2017 08:03 PM
evotuner04
14
Nov 24, 2016 03:41 PM
FS[MidWest]: MN: Evo 9 SE 55k Miles CLEAN!
evotuner04
For Sale - Cars For Sale
36
Oct 20, 2016 11:36 AM
