What you think of my cam install plans?
I plan on getting...
-Kelford 272s
-GSC Beehive Valve Springs, Retainers, and Spring Seats...Kit # 5041
Part number 5041 includes new 4340 Chro-molly spring seats (these won't crack like others aluminum seats) and GSC’s Titanium Retainer set. This kit is capable of 11000RPMS, with as much as 12.5mm of lift (or .285" of camlift). This is a must have for anyone pushing the limits. If you have had problems with valve float or throwing rocker arms this is the spring set that will cure your problems for good...
Spring pressure: Seat at 1.46"= 95 pounds .300"= 200 pounds .400"= 250 pounds CoilBind .560"
-Ferrea Valve Seals
-ARP Head Studs
-OEM MLS Evo 8 Head Gasket
-OEM Timing Belt Kit
-Walbro 255 Fuel Pump
And i'll pry retune to 24 psi...
Let me know what you guys think!
-Kelford 272s
-Ferrea Valve Seals
-ARP Head Studs
