Gear Synchros - Evo III
Old Mar 28, 2009 | 09:59 AM
94AWDcoupe's Avatar
snycros from picture
2nd=22546a
3rd=22547a
4th=22551a
5th=22596y
Old Mar 31, 2009 | 10:13 PM
EvoIIIAj's Avatar
You positive now?
I dont wanna order the wrong ones :P
Old Apr 1, 2009 | 06:26 AM
94AWDcoupe's Avatar
yes I am positive. but best to use actual part numbers.
2nd syncro MD746435
3/4 are same MD747255
5th MD745892
I have built 200 transmissions.
Old Apr 1, 2009 | 10:14 PM
EvoIIIAj's Avatar
Do you know anyone that could get a hold of them part numbers for me?
Old Apr 2, 2009 | 05:25 PM
EvoIIIAj's Avatar
Nevermind, got a hold of someone.
BTW - Are these synchros for a GSR gearbox?
Old Apr 2, 2009 | 06:07 PM
94AWDcoupe's Avatar
there are no gear or gear ratio changes in the early 1-3 boxes. so RS and GSR came with same ratios. only difference was RS came standard with front LSD and GSR it was an option. It wasnt till evo 4 came out were there were gear ratio changes and rear end ratio options, even then the scyncros used would be same.
but to be sure post the number of your box to be sure you have evo3 box.r
W5M332_ _ _ _
I need the last four letter to tell you which box you have.
Old Apr 2, 2009 | 06:25 PM
runuts's Avatar
From memory, I believe the ratios in evo 1 box's are slightly different to evo 2/3. That said though, there are no differences between GSR and RS ratio's. The Evo 3 however, has a different crownwheel and shaft, hence requiring a different ratio transfer case to the evo 1/2
Old Apr 3, 2009 | 05:00 AM
EvoIIIAj's Avatar
My box is a evoIII GSR box for sure.
Just didn't know RS had the same gears..
Old Apr 6, 2009 | 06:28 PM
EvoIIIAj's Avatar
Anyone know the part number for the Evo 3 bell housing?
Old Apr 30, 2009 | 08:51 PM
EvoIIIAj's Avatar
Question: Does 5th gear and reverse use the same synchro??
Old May 1, 2009 | 04:57 AM
EvoIIIAj's Avatar
Bump.
Old May 3, 2009 | 10:43 PM
EvoIIIAj's Avatar
Bump..
Old May 4, 2009 | 08:28 AM
94AWDcoupe's Avatar
5th and reverse do not use same syncro.
they would be same for all boxes.
Old May 4, 2009 | 01:04 PM
WADADLIG_OZ's Avatar
SUbscribed just for the information.
WADAD
Old May 15, 2009 | 05:51 PM
EvoIIIAj's Avatar
Does the eclipse use the same part numbers?
I've changed my synchro rings but still not totally satisfied with the way it feels, what else would be worn?
Is the hub/sleeve the thing that the synchro ring sits in?
