New evo owner, help please, big problem
it looks like the wrong fluid is in that reservoir. It should be red. Unless there's a different colored auto tranny fluid. As said above, tcase and acd fluid are totally different.
Wow... I think that Biggie's right. If I were you, I'd go to the dealer and get them to flush that out and put the red dyna queen fluid in. Also, make sure that banjo bolt is tight!
Yes I know they have differant fluids, but the point I was trying to make that if the t-case had been out of the car they would of had to rebleed the ACD. The ACD controls clutches inside of the t-case. So YES if he had a transfer case problem prior to him buying the car that could of been his problem.
wait... I reread the first post. If the fluid is leaking from the reservoir itself, Scottatyamaha is right you've probably got a bleed problem. Sorry for the confusion, I thought the level was way low, not high.
the car was checked out by TTP here in orlando and by another mechanic and it was fine, no T case has been replaced and i know when they redid the oil for the Tcase they told me after they did it it overflowed a bit, there is no trouble when you drive the car and shift, and nothing seems different, I just drove it again for a while and looked at it and nothing overflowed from the tank and it is all fine now. Im just wondering what it is? im going to the dealer on wensday to get alignment so ima ask them, but anyone on here have a good idea of why it would do that??
TTP-Engineering did no mechanical work or review of the car whatsoever outside of the dynotime and mild tuning to the ECU.
Transworld Auto where you bought the car claimed to have done all of the fluid service on the car.
We did not review or work on the car. A prospective buyer wanted the car dynoed and we did a little tuning on the car.
i took the car to mitsu today, they said that car was mixing the transmission fluid with the transfer box fluid and thats why it was coming out black instead of the pink it's suppose to be. so they are replacing my transfer box(under warranty thank god) and i should have the car back by monday or friday.
ok cool,
ok cool,
