ACD 3 solid lights after transfercasse replacement
Old Apr 8, 2009 | 12:27 AM
Danieln's Avatar
Hi Guys,
I face a strange issue with the ACD unit to an EVO 9 RS.
The car recieve some modifications in accordance with Group N cars.
It`s a car prepared for rally championship N Gruppe.
After the transfercase was changed, the ACD unit enter into a fault code and all the 3 lights are on at the same time.
So the differential is not doing no longer pressure.
Strange thing is that I face this issue only with the original ECU. If I switch the modified race ECU, the differential respond and the error disappears so the lights became normal.
I know that at Mitsubishi dealer there is a special way to engage the ACD pump
What is all about?
Can I do something in order to fix this issue?
Thanks
Old Apr 8, 2009 | 12:31 AM
Cronic's Avatar
Sounds like the system wasnt bled properly.
Old Apr 8, 2009 | 12:38 AM
1320 Engineering's Avatar
^ +1 just came here to post this.
Old Apr 8, 2009 | 01:00 AM
Danieln's Avatar
what about the issue with the second ECU?>
why with a modified ECU (engine ECU) the differential respond?
Still ..... dont know what is the issue.....
Old Apr 8, 2009 | 05:19 PM
dancarroll0283's Avatar
The t-case has to be bled. I know sometimes with modified ECU's they aren't as sensitive as the stock ECU. Bleed the t-case and you'll be fine!!
