boost problem. help please
Old Apr 9, 2009 | 12:29 PM
danny88m's Avatar
ok, it all started with changing the clutch on my evo 8. it was down for about a week. everything was put back to how it was. i was running 22psi on a greddy type S (EBC) now after putting back everything back together it doesn't want to go above 17psi. the setting on the type s were the same. so i came to the conclusion that maybe the solenoide went bad. so i change back to a MBC i previously had on set at 20psi and again it would not go above 17psi. i have stock evo 8 turbo w/10.5 end. i'll appreciate any help i can get. thanks
Old Apr 9, 2009 | 10:39 PM
Venividivichi00's Avatar
check for boost leaks im pretty sure there is a thread on it in the how to's section
