help!!!
Old Apr 9, 2009 | 01:10 PM
danny88m's Avatar
help!!!
ok, it all started with changing the clutch on my evo 8. it was down for about a week. everything was put back to how it was. i was running 22psi on a greddy type S (EBC) now after putting back everything back together it doesn't want to go above 17psi. the setting on the type s were the same. so i came to the conclusion that maybe the solenoide went bad. so i change back to a MBC i previously had on set at 20psi and again it would not go above 17psi. i have stock evo 8 turbo w/10.5 end. i'll appreciate any help i can get. thanks
Old Apr 9, 2009 | 01:16 PM
N3VO's Avatar
leak?, i would boost leak test it
Old Apr 9, 2009 | 01:18 PM
evokid511's Avatar
im willing to bet anything that its a boost leak!!! definitley do a boost leak test then go from there
Old Apr 9, 2009 | 08:02 PM
FX11's Avatar
check the forums for How-TO do self boost leak test
