Glove Box Power Source
Old Apr 12, 2009 | 10:04 AM
Maximum404's Avatar
Veteran: Navy
I am outside wiring up my gauge pod in the glove box and can't see any power source readily available. Can someone recommend one to me? I have the Tech Manual so if someone has a page number with a diagram that I missed that would help as well. Thanks!
Old Apr 12, 2009 | 10:39 AM
evokid511's Avatar
your trying to find a power source for your gauges that youor mounting in the glove box?? i always get my power form the fuse panel on the driver side just run a wire from there?
Old Apr 12, 2009 | 11:07 AM
Maximum404's Avatar
Veteran: Navy
I was thinking about it, but I think that most of the work was done for me. I have the stock gauge wires that I pulled out and I just need to figure out which ones were the positive. They had Yellow, Red, Black, and white wires running to the stock guages. I am trying to track down a wirin diagram, but no luck so far.
Old Apr 12, 2009 | 11:10 AM
evokid511's Avatar
oooo ok i see... well i didnt get an MR so not sure about the wiring diagram but if you have an electriacl tester it should be a piece of cake but if not then all i can say for sure is black is gonna be your ground haha sry
Old Apr 12, 2009 | 11:11 AM
Maximum404's Avatar
Veteran: Navy
Yeah, off to the store for me.
Old Apr 12, 2009 | 03:38 PM
barneyb's Avatar
Lighter?
Old Apr 12, 2009 | 04:48 PM
Maximum404's Avatar
Veteran: Navy
The stock gauge power wires are perfect and actually reach over to the glove box. Ther are only two powered wires that will reach, but I am sure that I can supply the power necessary from those two. The stock boost sensor hose is also right there when rerouted. This install is going to be a breeze and anyone with the gauge pack stock should have a very easy time doing aftermarket gauges.
Old Apr 12, 2009 | 05:09 PM
dancarroll0283's Avatar
That harness that comes in the Evo's with the stock guages makes putttin aftermarket guages in super easy!
