Boost Question
Old Apr 14, 2009 | 11:11 PM
IXEvolutionIX's Avatar
Boost Question
Ok, so when I am cruising on the highway and I am not boosting the car is fine. But when I accelerate, I cant just give it a little, because when I try and keep it at say 6-7 pounds the car stutters really bad. Only when I really get on it like I am hauling *** does it not do this. Would getting a flash fix this? Or is this another issue all together. My mods right now are TBE, test pipe, MBC, HKS suction, HKS SSQV, and UICP.
Old Apr 14, 2009 | 11:42 PM
evo unknown's Avatar
do you have a tune? the car's ecu may not be registering ur mods without a proper tune, therefore, throwing a safety code and limiting boost as a precaution.
Old Apr 15, 2009 | 05:16 AM
JakeTheVIII's Avatar
I know exactly what you're talking about. It does it especially bad if you have a non-recirculating bov. If you have a vent to atmosphere blow off valve, that's why. If not, try getting a fresh tune, or asking tuners.
Old Apr 15, 2009 | 05:23 AM
cush87's Avatar
I would def say it's your bov. I went through the same thing with my greddy rs I had. Partial throttle was almost impossible to do. I switched the greddy unit out for an APS dual vent and no more problems. The APS unit is awesome. I def recommend it if you decide to get some thing other the HKS unit you have now.
Old Apr 15, 2009 | 07:12 AM
AWD_Terror's Avatar
Mine was doing this too on my recirc Forge RS. Was set too tight IMO. I loosened it quite a bit and its better, but still does it a little.
Old Apr 15, 2009 | 12:24 PM
Yea I figured it was either the BOV or the stock ecu. I plan on getting it tuned once I get back to the states in a couple months. Does anyone know if HKS has an adapter for the SSQV to recirculate it back to the turbo?
Old Apr 15, 2009 | 01:12 PM
AWD_Terror's Avatar
they did sell them in the past. Im sure they still do.
