Weird Problem Help Needed ASAP!
Old Apr 16, 2009 | 11:56 PM
aguita's Avatar
Today I accelerate the car to 6k rpms and suddenly the car bogs down like a Pipe Was loose..I came to a stop and the car is hunting idle like crazy but If you give it throttle it accelerates..I moved the car and It runs fine but when you go to 2k rpms it start to cut like is starving for fuel..
Also I noticed that my BOV sounds when you rev it like the car has compressor surge..
All vac lines looks fine
LICP and all pipes are connected..
Car start and the engine doesnt sound weird..
Plugs are 3k old
No CEL..
Just this random misfire on idle like the car is running on 3 cyl and is Smoking black when you rev it.
Where should I look at??
Old Apr 17, 2009 | 05:51 AM
JakeTheVIII's Avatar
Boost leak test
Old Apr 17, 2009 | 07:00 AM
evokid511's Avatar
you def have a boost leak thats exactly what its like!
Old Apr 17, 2009 | 10:16 AM
gsrboi80's Avatar
Could also be that your DV is on backwards.
