***please help asap evo sounds like dying turkey when boostin!!!*** need to drive car
Old Apr 17, 2009 | 12:19 PM
dairyman's Avatar
hey guys just got me 03 evo so I do not know that much about them yet.
hre is the deal the car was running great then I went for a drive today and about 5 min into the drive i noticed the car felt much slower... then I went to accelerate and when it started to boost it sounds like a dying turkey or like someone blowing air through a ballon that has popped like the screeching kind of screaming sound.
I checked the intercooler hoses but didnt really notice anything off.
please help ASAP thanks!
Old Apr 17, 2009 | 12:25 PM
dairyman's Avatar
the car didnt make a pop or bang noise which i heard could be a hose blowing off
Old Apr 17, 2009 | 12:29 PM
YellowFever's Avatar
^ it did or it didnt? because if if didnt then ur just probably getting a # amount of knocks and u must be pulling timing...idk have it checked...are u tuned?
Old Apr 17, 2009 | 12:33 PM
dairyman's Avatar
it DID NOT make a loud pop noise the car idles fine etc it just happened all of a sudden.
Old Apr 17, 2009 | 12:45 PM
dairyman's Avatar
i was just driving it again it sounds like an air leak (high pressure) just going by the sound. it doesnt sounds like a knock at all.
Old Apr 17, 2009 | 12:47 PM
lords3t's Avatar
you throwing a code?
Old Apr 17, 2009 | 12:48 PM
monkey_187's Avatar
check all you ICP's and make sure all your clamps are tight
Old Apr 17, 2009 | 01:06 PM
dairyman's Avatar
no CEL which seemed weird as well. Really seems like some kind of a hose leak. I am going to tighten them all see if it makes a difference. anything else you can think of?
Old Apr 17, 2009 | 01:15 PM
Evojun8's Avatar
maybe you should give it a good tune up ,change all hoses, clamps oil coolant fluids ect.... just for piece of mind.
Old Apr 17, 2009 | 01:41 PM
dairyman's Avatar
I tightened all the IC hoses. no luck. It sounds more like a ballon filling with air it sqeels. but if I accelerate past 5000 it goes away or I can t hear it anymore. Noticable decrease in performance as well.
Old Apr 17, 2009 | 03:10 PM
RoadSpike's Avatar
Take off your intake tube and check the turbo for play.
Old Apr 17, 2009 | 05:12 PM
dairyman's Avatar
guys I figured it out... No way anyone would have figured this out by my description but basically the owner before me put a CAI on the car and must have taken a vac hose off the top IC pipe and had put a piece of tape there to hold pressure. Well I didn't see it because it was underneath but that was what was causing the noise. Now i just need a diagram of someones engine bay that has all of the hose hooked up properly so I can fix mine!
but thanks the car runs great again.
Old Apr 17, 2009 | 05:32 PM
justa4banger's Avatar
lmao...... sounds like a dying turkey???? that was the funniest thing i eve heard...lmao
