trouble getting into reverse
Old Apr 19, 2009 | 08:40 AM
dpl2's Avatar
Recently had Exedy twin plate HD clutch put in after I blew the stock clutch. Immediately started having trouble getting into reverse. Is that possibly a sign of a bad install? I have an 06 MR 6 speed putting out nearly 400 hp and 420 tq (green turbo, FP cams, buschur exhaust, meth injection).
I also recently replaced the under hood bushings with Speed Source bushings. Seems to have made it even worse...
Anyone had similar experience after installing either product?
Old Apr 19, 2009 | 08:42 AM
justa4banger's Avatar
adjust your clutch pedal...
Old Apr 19, 2009 | 05:13 PM
evolved0414's Avatar
There are a few threads on here about adjusting your clutch pedal, but also if you go to www.evomoto.com, there is a picture step-by-step setup.
I had the same problem and this was a 10 minute fix! Hope this helps!
Old Apr 19, 2009 | 05:33 PM
dpl2's Avatar
Thanks, I'll give it a shot.
