Helppp..Nasty noise and feeling in clutch pedal
Old Apr 19, 2009 | 07:06 PM
brandon1304's Avatar
Car has 62k and 3k on ACT 6-puck sprung and flywheel..
OK... i need some help...Washed the car and took it for a quick ride and got on it pretty good in 1st and the tires broke loose so i let off, push the clutch in to shift into second , put the shifter in second and as i am letting of there is a horrific spline agaisnt spline (grinding) in the clutch pedal (while in the process of engaging the clutch) . Once my foot is completely off the car runs and shifts fine, but every time i try to engage the clutch i get a that horrible grinding and spline on spline feeling. The actual shifting feels find not notchy at all..
I drained trans and transfer case fluid, No metal or particles or pieces
Pulled the axels. good shape
Pulled the transfer case... everything is good to go
about to pull trans now...
any ideas???? Someone said maybe the throwout bearing is seized??
Old Apr 19, 2009 | 08:02 PM
bumpp
Old Apr 19, 2009 | 09:13 PM
anyoneee??
Old Apr 19, 2009 | 09:58 PM
justa4banger's Avatar
maybe your clutch disc springs came apart...
Old Apr 19, 2009 | 10:00 PM
Evo8luva's Avatar
^^ agreed, you probably broke the clutch disk
Old Apr 19, 2009 | 10:02 PM
happen to mine after 3k miles of use...sucks but o well
Old Apr 19, 2009 | 10:10 PM
broke a clutch disk???? were you having the same symptoms... you can feel the grinding in the clutch pedal almost?>>
Old Apr 19, 2009 | 10:20 PM
badhabit90's Avatar
well that sucks...i have the same clutch. i have some decel noise, but nothing like what your describing...ugh...
Old Apr 19, 2009 | 10:29 PM
Yea..it would grind loud...I actually thought it was my gears in the tranny but than I pulled the tranny and saw that the springs fell off
Old Apr 19, 2009 | 10:38 PM
oh god ACT strikes again..... any other input?
Old Apr 19, 2009 | 10:54 PM
pull your tranny off
Old Apr 19, 2009 | 10:56 PM
MajorGunHo's Avatar
Seconded!
Old Apr 20, 2009 | 07:05 AM
hoping to get the trans out tonight... any other input?
Old Apr 20, 2009 | 07:10 AM
blownevo's Avatar
GL with everything. Hope you fix the problem.
Old Apr 20, 2009 | 08:07 AM
keep us posted on what you find
