Forge EVO15 Bov??
Old Apr 22, 2009 | 12:34 AM
ant_turbo's Avatar
Forge EVO15 Bov??
Ok I have the a FORGE BOV FMDVEVO15..(YES Recirculated)
Normal driving bov works perfect...
And I have the red spring installed and
at part throttle the bov will flutter very badly;; Like when I am speeding up
on the FWY,,,, Once I start to get into boost.....???
THANKS,,
Old Apr 22, 2009 | 06:01 AM
AWD_Terror's Avatar
Im starting to see a trend here with Forge Valves.
Mine does the same ****. i called them and they told me to loosen it. I did much and still does it.
Im gonna totally loosen it at lunch and go from there.
this thing is gonna get sold soon.
Mine is the RS BTW
Old Apr 22, 2009 | 08:26 AM
DS-03evo's Avatar
THANKS,,
Put the lighter spring in it. It will drive much better. Also will still hold the same amount of boost.
I logged boost with all three different springs and they held the same pressure, with much better drivability.
Old Apr 22, 2009 | 08:50 AM
AWD_Terror's Avatar
What spring are in those things stock?
If he swapped the spring would it hold then on full boost?
Old Apr 22, 2009 | 11:45 AM
ant_turbo's Avatar
I put my stock evo 9 evo back in and no problem,,,
I guess I will try a diff spring..///////////
Im not sure what spring it came with,,I bought it used and the guy had the heavy spring in,,(red) But I do have the green and yellow springs,,,
Old Apr 22, 2009 | 02:19 PM
DS-03evo's Avatar
Try the yellow spring, and report back.
Old Apr 22, 2009 | 05:32 PM
AznDragonV's Avatar
what gear are you in when your boosting on the highway? when i used to boost in 5th gear at low rpms it flutters. so whenever i have to pass someone i downshift to 4th and then boost away and then shift back to 5th.
boosting at low rpms puts a lot of strain on the engine.
Old Apr 23, 2009 | 11:56 AM
AWD_Terror's Avatar
I jsut talked to Forge because I got the ***** of my RS.
They are sending me a softer progressive spring to try out. They said if that doesnt fix it then they will gladly refund me. I am happy they offered that level of service. Not many do that anymore.
For reference they have had a handful of the Evo15's reported with this problem. I called my friend locally that has one too that I was gonna swap his in to see but he said his does this too
So Ill let yall know how my works with the smaller spring in it, but id try that if you already have other springs.
Also he said about taking the valve apart to make sure their is free movement of the valve. Maybe use a little grease on it.
