Head gasket differences?
Old Apr 24, 2009 | 02:21 PM
fvaldes's Avatar
Any idea on the thickness of the OEM Mitsubishi head gasket? Cosworth sells a 1.3 mm and a 1.5mm. , how much compression in a 2.3l motor will one gain or loose over the other?
Old Apr 24, 2009 | 06:44 PM
loosecannon's Avatar
oem is 0.8 mm , you got to measure the head volume + gasket volume vs the head+gasket+cylinder volume to be accurate . the cosworth big valve head volume is about 46.5 cc to 46.8 cc .
