evo 8 with evo 9 turbo
Old Apr 25, 2009 | 06:12 PM
ellyottlin's Avatar
i was thinking about changing my turbo to an evo 9 turbo. what will i need besides the turbo itself? thanks
elliott
Old Apr 25, 2009 | 06:23 PM
beemerfreak's Avatar
I think you will need a install kit....
Old Apr 25, 2009 | 06:44 PM
ar3nbe's Avatar
For a perfect fit. Oil feed line, and both water lines. You will also need the compressor outlet, as the stock 8 outlet, will just touch the starter motor cover on a 9 turbo.
If you want to grind away a fraction at the starter motor cover, the 8outlet will fit.
It is apparantly possible to use the stock water and oil lines too, but, I am yet to try this.
Old Apr 25, 2009 | 07:03 PM
ellyottlin's Avatar
ooo cool thanks for the info! it helps a lot!
Old Apr 25, 2009 | 07:05 PM
partyboy1122's Avatar
Yes you can use the VIII lines.
Really only need the IX outlet pipe to make things come out smooth.
Old Apr 25, 2009 | 07:06 PM
Fast_Freddie's Avatar
Veteran: Navy
Most people will tell you that you only need the XI j-pipe and the turbo feed line, and new crush washers for this to bolt up. I am however **** and opted for the XI install kit from Russell at mitsubishiparts.net. You will need a few extra crush washers and such if you get his kit...
Old Apr 25, 2009 | 09:19 PM
huevosrancheros's Avatar
just need an install kit. I believe gruppe-s is having a deal right now for the evo9 turbo w/ the install kit for $799 shipped. That is a hellova deal.
Old Apr 26, 2009 | 12:34 AM
Gordian79's Avatar
crush washers are one time use only.to avoid bs later just get new ones.
Old Apr 26, 2009 | 04:05 AM
Evo8Emperor's Avatar
This has been covered so many times and you dont need anything besides the j-pipe. I installed my 9 turbo with out any install kit and everything is fine. Save yourself the money for something else.
Old Apr 26, 2009 | 06:27 AM
Nope. No need for an install kit.
Seenoevol
Jan 28, 2015 05:14 AM
sharky559
Nov 23, 2010 06:18 PM
playmajohn
May 22, 2008 07:12 PM
EVO8emUp
Apr 6, 2008 07:35 PM
3000ways
23
Mar 9, 2006 01:12 PM
