oil light
Old Apr 28, 2009 | 05:04 PM
wiggam11's Avatar
oil light
my light comes on just at idle or coasting with clutch in etc and only when its warm out like 60 or higher all winter no light at all, it only stays on for 10-15 seconds then goes away or if i slightly touvh the pedal and i mean just bump move it 1/4 of an inch it goes away while bleeped, but mostly just stays on for 10-15 seconds
Old Apr 28, 2009 | 06:04 PM
1d10t's Avatar
Check your oil level. What oil are you using?
Old Apr 28, 2009 | 06:07 PM
aeroweenie's Avatar
Check the sending unit. There are some past threads about this. If the sender is ok, then something else is going on (oil pump perhaps).
My oil light would flicker after a track session, which gets the oil really hot. Fixed by running 10W40 oil. But this should not happen in normal use, so check it out, don't just run thicker oil. I also installed oil pressure & temp gauges since I don't trust the simple oil light.
Old Apr 28, 2009 | 06:21 PM
wiggam11's Avatar
just changed oil on saturday using mobil1 5w30, where is the sender unit located at
Old Apr 28, 2009 | 06:43 PM
Berts24's Avatar
I was having the same problem when I was running 5w30, I did it just for the winter and it started doing it one day. I changed it two weeks ago and went back to 10w30 and haven't seen it yet.
